started turbo up, bad sputtering
Old Mar 31, 2005 | 07:07 AM
  #31
twinring's Avatar
twinring
Originally Posted by edecho
damn alright thanks for the info im gonna try to find a diagram.
my car was left at my school because my shop had the tools, so i worked on it during school, then spring break came, now the 2nd day of spring break, 3 shady mexicans came up to me and asked me questions about my car and i kinda told him too much about my car, my car doesnt have an alarm, so i had to get my car outta the school lot. soo. when i told my dad i need to get my car towed, he called AAA and the tow truck driver came, the bitch told me he doesnt tow modified cars, so he ****ing left. i went home and posted on the forums so i can get my car started and out of there. my dad comes into my room and starts yelling and cussing, throwing my boxes around (never does this) claiming i modified my car too much and all that bullshit. i go back to school and was aobvut to drag it with my damn honda odyssey then my dad comes. starts yelling for 3 hours straight, calls AAA and calls the lady a ****, got in my face, was gonna hit me dozens of times.. blah blah blah so now my car's at my friend's house. i need to get my car started or my dad is going to take my car away and take an priveledges away and hire a mechanic to fix it.
(sorry for the long ass story)
i need to get my damn car fixed and i think the map sensor is the only problem now?
does anyone else have the diagram?
hey man, whats wrong with mexicans?
Old Mar 31, 2005 | 12:57 PM
  #32
RboYi's Avatar
RboYi
shady mexicans that drove into the school lot just to scope my car out, in my town, its all white people, rarely do u see diverstiy so it was kinda... weird
hey shmoo, my car doesnt seem to be boosting, at like 5k rpms, the boost gauge goes to 0. the manifold seems to be smoking, also the exhaust is blowing out some smoke?
Old Mar 31, 2005 | 01:17 PM
  #33
RboYi's Avatar
RboYi
ok so i just drove it in 1st and 2nd gear it wouldnt boost, but in 3rd gear the psi went up, hmm? (btw that was orgasmic)
Old Mar 31, 2005 | 08:41 PM
  #34
Provocateur's Avatar
Provocateur
On permanent hiatus
It is hard to get it to boost in 1st gear unless you floor it but every other gear, you shouldn't have a problem. It is normal for the manifold to smoke since it is burning off the outer coating. What color is the smoke blowing out of the exhaust?
Old Apr 1, 2005 | 12:05 PM
  #35
RboYi's Avatar
RboYi
ok everyone seems to work nicely, just wondering what's that noise when i shift? wastegate actuator?
Old Apr 1, 2005 | 05:46 PM
  #36
RboYi's Avatar
RboYi
or turbo just stops spinning, also what idle does ur car sit at? mine is at like 1500
Old Apr 1, 2005 | 07:01 PM
  #37
Provocateur
On permanent hiatus
The noise is the shockwave that is produced when the throttle closes. The shockwave is rattling the turbo wheel against it's thrust bearings. That is why you need a blow off valve. If you don't get a blow off valve, expect to rebuild the turbo very soon.
My idle is around 750 rpms. It fluctuates a bit because I have an open atmosphere bov that leaks at idle.
Old Apr 1, 2005 | 09:36 PM
  #38
RboYi's Avatar
RboYi
is there a reason why my idle is double yours? psi is at -20 if that helps any
Old Apr 2, 2005 | 04:14 PM
  #39
Provocateur
On permanent hiatus
I don't know. The vacuum sounds normal, so it can't be a leak. How many miles do you have on the turbo now? Could have something to do with the IACV or something...
And it isn't -20 psi. Vacuum is measured in mm/hg, not psi.
