Shaking issues
Old Feb 26, 2005 | 02:44 PM
dubcac's Avatar
dubcac
I
Originally Posted by Shmoo
So I replaced my fuel filter but I still have the same problem. So I can rule out fuel as a culprit for the shaking. The last step I do before I take it to a mechanic is balance the tires and get an alignment. If that doesn't fix it, the problem is out of my hands.
Check the tires/rims for being out of round as well.
Old Feb 26, 2005 | 04:33 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by coltank
Possibilities I can think of are this:
1.Tires/rims/alignment
2.motor mounts-Did you tourque them real well with a wrench
3.let's hope it's not internal
1. I am going to get it aligned and the wheels balanced as soon as possible.
2. I have never removed a motor mount from this car.
3. It definitely isn't. It has to be a wheel/axle/motor mount problem.
Old Feb 26, 2005 | 05:09 PM
coltank's Avatar
coltank
You said you checked the motor mounts. How did you check them?
Old Feb 26, 2005 | 05:18 PM
dubcac's Avatar
dubcac
I
I would assume he checked them for tears.
Old Feb 26, 2005 | 09:41 PM
Provocateur
On permanent hiatus
I just glanced at them a bit. I didn't really do anything to test them because I don't know what I should do. It seems like the shaking is coming from the passenger side, so maybe a tranny mount or rear engine mount? Like I said, I didn't really check them that thoroughly but if you have a good way to check, I would be gracious to try it out.
Old Feb 27, 2005 | 05:08 AM
coltank's Avatar
coltank
You want to try to get a socket on to them and then flex the mount itself. You shouldn't really get a whole lot of movement from the mount itself. I'v had some that were busted before, and you could see the whole inside move. Also, ending on how long you've been running the car with that engine it may be a good idea to change them anyway. A turbocharged engine can put a lot of stress on motor mounts, and if by any chance you've ever had some kind of fender bender, that could stress them out a lot as well.
Old Feb 28, 2005 | 10:24 PM
Provocateur
On permanent hiatus
I inspected the mounts tonight and I found that every one of them was fine except for the left front mount next to the timing belt. The bushing was totally ripped up and it had a bunch of play in it. I don't know if that is the problem but I will replace it and keep you guys updated.
Old Mar 1, 2005 | 03:41 PM
dubcac's Avatar
dubcac
I
Definitely replace that mount and it'll help.
Old Mar 1, 2005 | 05:31 PM
Provocateur
On permanent hiatus
I am going to check all the other mounts really thoroughly tonight so that I can replace all that are bad/failing so I won't have to deal with this again.
Old Mar 5, 2005 | 03:32 PM
Provocateur
On permanent hiatus
So, I replaced the motor mounts that were bad: right and left front and it still has the problem. It just moved the shaking from 40-70mph to 50-70mph. I am really out of ideas as to what it could be. So can anyone think of a logical expanation as to why the car shakes only while accelerating and going 50-70mph?
