Shaking issues
On permanent hiatus
Originally Posted by toukna
hahaha... check this check that
"I replace this, I replace that"
By the time your'e done, you're going to have a new car!!!
Check your front lower sway bar. If good, it may be your wheel bearings, maybe they need to be replaced or repacked. had a similar problem with mine. Replaced axle, and got bearings replaced. If you don't get the bearings checkd your tire can lock up and send you rolling. NOT GOOD!!
1. Alignment
2. Tires balanced
3. Replace Axle
4. Check sway bar
5. Check wheel bearings
6. Check tire for weird or irregular wearing.
If you still haven't resolved this issue after all that you have done, just go to a mechanic.
1. Alignment
2. Tires balanced
3. Replace Axle
4. Check sway bar
On permanent hiatus
I actually just replaced the drivers side axle with a brand new axle and fixed the problem. I guess the remanufactured axle from expressautoparts.com was faulty either due to a bad inboard joint or bent shaft. I know I won't be seeing that money from them since I haven't gotten my core back either. Good thing the BBB is on their ass. :chuckles: I am just glad I got it fixed without having to take it to a mechanic. I guess the third axle is the charm. :rick:
I think your problem with the shaking with your car has come over to my car now , I know yesterday i peeled out of a parking lot smoked the tires, and then this morning on the way to work I notice the steering wheel shaking at 40-50mph and i also known for a fact that i get the clicking noises when i always turn to the left... so i look at my cv boots and i see there completly torn apart ... im just debating to get the remanufactured o.e. drive shafts or high performance drive shafts
On permanent hiatus
I got a brand new axle from ebay. It worked a hell of a lot better than the autoparts.com axle and was cheaper with no core to deal with. Total with shipping was $82.00. You don't need performance driveshafts, so stick with OEM like 2legit2quit said.
