Shaking issues
I had a similar problem and it was because I had a nasty bubble in my front tire. Might want to check that. The symptoms were exactly the same, car shaking when driving above 20mph, steering wheel shaking, etc.
On permanent hiatus
Originally Posted by Master Yodub
I dont think rotors would have much affect except under braking, unless they were warped so far that they caught the pads. I know you said your driver side axle was replaced, but did you check it when you replaced the passenger axle? Other possibilities would be defective/bubbled tires, or bent rims.
It could be a motor mount for sure.
On permanent hiatus
You could buy some used mounts that weren't torn, or buy some mount inserts.
On permanent hiatus
So, I checked my motor mounts when I replaced my rings and they were fine and I replaced all four rotors this week and it still shakes. My girlfriend thinks that it may be the fuel filter since it only shakes while accelerating from 40-80 mph. I am don't really believe it has anything to do with the fueling but rather the chassis or drivetrain. Is there any reason to be believe that what she is suggesting is true? Let me know, because I am on the brink of having a mechanic diagnose it so I can fix it.
Is it only under acceleration, or does it do it while coasting or in neutral?
On permanent hiatus
It is only under acceleration between the speeds of around 40 mph to about 70-80 mph. After that it stops shaking. I am going to get my tires balanced and aligned this weekend as this is the last thing I can do before just giving in to the outside help of a mechanic.
On permanent hiatus
So I replaced my fuel filter but I still have the same problem. So I can rule out fuel as a culprit for the shaking. The last step I do before I take it to a mechanic is balance the tires and get an alignment. If that doesn't fix it, the problem is out of my hands.
