anyone lower their own?
Old Aug 17, 2002 | 06:14 AM
silvagsr's Avatar
silvagsr
Default anyone lower their own?
Has anyone lowered their own teg... I know that they have to be realligned later on...but my question is how hard is it to lower your teg on your own with no air tools? I really dont like letting others do work(aftermarket that is) on my car so I am thinking about taking the weekend off and installing some competch sport springs and possible tokiko struts and shocks.
One more question, Do you have to trim the bumbstomps on the front? Comptech recommends it, but I dont know?
Old Aug 17, 2002 | 06:47 AM
LOwrestling2001's Avatar
LOwrestling2001
i did mine with my friend...well we swapped my car from neuspeed to eibach springs and kept my tokico shocks and that took all of like 30-45 minutes. it's real easy, just make sure u have some Liquid Wrench in case **** is stuck, and a ratchet extension for more leverage. You will also need a spring compressor, lots of places rent them for a small fee or even for free (autozone). as for trimming bumpstops i didn't need to, but u mite have to i dont know.
Old Aug 17, 2002 | 07:27 AM
reno96teg's Avatar
i lowered my teg with my dad. everything went smoothly except for the seized bolts on the rear LCAs.
you'll need spring compressors, and we did use an impact wrench. torque wrench is a must too.
i'm glad we did it ourselves tho, even though the rear was a bit of a pain. i wonder how a shop would have handled it.. :nono:
Old Aug 17, 2002 | 08:44 AM
Wolverine's Avatar
Wolverine
I lowered mine without the use of air tools. If I can give you one piece of advice it would be to soak down all your bolts/nuts with some type of penatrating lubricant once a day for 3-4 days. I had no trouble with any bolts being frozen.
Old Aug 17, 2002 | 08:56 AM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
I also lowerd my car myself. The front end went smooth as hell, did the front two by myself in about 45 minutes (I work damn slow too )
The back was a different story, I had a siezed bolt on my rear left LCA, and managed to break the head off the bolt
After trying to drill the bolt out, I just cut the stock shock off and replaced to bushing and the rest was easy
I don't know how old your car is, but mine was a 95, if your car is newer I'm sure it'll go more smoothly.
Old Aug 17, 2002 | 09:03 AM
ur31337's Avatar
ur31337
Colby
My friend's dad & I are about to lower my girl's civic (GR-2s w/ H&R OE .75") this weekend or early next week.
Then I get to start saving for my ish.
Old Aug 21, 2002 | 06:53 PM
tub_sephiroth's Avatar
tub_sephiroth
I think most people lower their own tegs. It's so easy. It might help if you had a friend. You can do it without any air tools, it just takes longer.
Old Aug 21, 2002 | 07:46 PM
JackoliciousLeg's Avatar
JackoliciousLeg
root
We lowered my friend's teg and a rear left bolt was seized too! It was just that one... we had already done the front, so we left the rear at stock height until he could get it to a shop!
JackO
Old Aug 21, 2002 | 08:10 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Having a good spring compressor makes the whole job very simple. Removing the rear shock assembly is a pain if you are by yourself.
Old Aug 22, 2002 | 02:30 PM
b00gers's Avatar
b00gers
me and my friend redid my susp 3-4 times....im forgeting....with do airtools either.
my car was fairly new, so no stuck nuts.
