Difference between RS and GS-R
Old Sep 30, 2004 | 11:45 AM
  #31
LT's Avatar
LT
The deer had to die!
Originally Posted by 94GsArrr!
coupe? not 3 door hatch?
coupe = 3 door hatch
Old Sep 30, 2004 | 12:19 PM
  #32
WackyRicky's Avatar
WackyRicky
redoing the interior
well, technically it is not true. however as far as its overall shape, i guess you can call it a coupe.
Old Sep 30, 2004 | 01:10 PM
  #33
LT's Avatar
LT
in the integra world...it's called a coupe.
Old Sep 30, 2004 | 03:33 PM
  #34
Deagle's Avatar
Deagle
Nüb
wowzers..lots of misleading info in here:
GSR/GS/LS/SE/RS all have 4-wheel disc brakes STANDARD! There are NO differences between subframes on these models. The GSR was equipped with a 24mm front sway bar, the submodels had a 22mm (94-7); 98-01 GSR submodels then upgraded to 24mm as well. GSR had 14mm rear whereas the 94-7 LS/RS/GS/SE coupes had 13mm (sedans had 14mm), then 98-01 ALL models (minus the ITR) upgraded to 14mm rears as well. There is NO difference in spring rates or dampener stiffness between the non-ITR models. The GSR did get a front strut bar STANDARD unlike the RS/LS/GS/SE models.
The RS does NOT have a stiffer chassis than the ITR, as the ITR has reinforcement in the roof, b-pillars, and the rear wheelwells and arch extensions were made thicker - including subframe reinforcement.
Brakes: same diameter rotors (front and back) among the non-ITR models.
94-5 GSR motors had a simple oil cooler equipped from the factory, 96+ GSR's did not.
Isn't there a difference between the GS-R front sway bar assembly and those of the RS and LS? I have an LS and I remember looking into getting a GS-R or Type-R front sway bar put in but it involved replacing more than the bar and bushings. There was like a ball joint or something.
Also, isn't the exhaust system on certain model year GS-Rs slightly different?
On a side note: I think we were comparing the stiffness of the chassis of an RS w/B18c to a GS-R (and not to a Type-R) where the chassis of the RS would be stiffer since it doesn't have a moonroof.
Old Sep 30, 2004 | 03:40 PM
  #35
Snoopy's Avatar
Snoopy
been there done that
yes. the 00-01 gsr's have a longer a-pipe so the cat is a few inches further back than where it is on 94-99 gsr's.
Old Sep 30, 2004 | 03:55 PM
  #36
LT's Avatar
LT
which is why those of you 00-01 GSR owners that sometimes finds some manufactures don't have a header for your year model...buy the 94-99 LS header.
Old Sep 30, 2004 | 05:24 PM
  #37
WackyRicky's Avatar
WackyRicky
Sorry man, i was just trying to be precise since, well generally speaking,
the definition of a couple is a 2-door car with relatively low roof and sleek overall body design + trunk as far as i know. I wasn't trying to be an asshole or anything.
Old Sep 30, 2004 | 05:32 PM
  #38
LT's Avatar
LT
no problem here, some call it a coupe (like me) and some call it a hatch...it's basically a thin line with this car.
Old Sep 30, 2004 | 07:45 PM
  #39
Deagle's Avatar
Deagle
Nüb
Mine Integra has a moonroof which has on occasion been used as a forth door by drunks.
Old Sep 30, 2004 | 08:02 PM
  #40
LT's Avatar
LT
LOL!!! i've done that before...almost dislocated my shoulder in the process h:
