Difference between RS and GS-R
Old Sep 23, 2004 | 07:20 PM
GSR4444's Avatar
GSR4444
Originally Posted by NorCal DC4
I'm sorry, but that guess is incorrect.
My 97 LS came with 4-wheel discs from the factory.
The Acura literature from that time period also backs me up.
All 3rd gen Integra models had 4-wheel disc brakes.
The RS is deprived of ABS, but the discs remain.
then how is it that my brother has a 96 ls with rear drums (I swear that he does, but i could just be mistaken)? anyways, I am probably wrong, i trust ur word.
Old Sep 23, 2004 | 09:15 PM
LT's Avatar
LT
The deer had to die!
ALL G3 integras were equipped with 4-wheel disc brakes...whether they had ABS is a different story.
Old Sep 24, 2004 | 09:13 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Here's my guess... FWIW..
Since the rear trailing arms are interchangeable with the EG Civic, it is possible that a prior owner replaced a set of bent trailing arms on teh cheap by throwing on a pair of EG Civic arms. :dunno: If those arms were from a CX or HX, that would explain the presence of rear drums.
It's certainly not something that I would do. :eek3: In fact, if your brother drives enthusiastically, he'd be better off IMHO switching back over to rear discs. h:
Again, I haven't seen the car (obviously), so this guess is a shot in the dark.
Old Sep 24, 2004 | 04:39 PM
pomansouth's Avatar
pomansouth
ok, you got a few points that I was already aware of. These points besides the suspension are mostly minor things. Like a strut bar, it doesnt help as much as sway bars. One mm difference in a sway isnt going to make that much diff either. The biggest thing that the R has over the gsr and rs is suspension. Other then that not really anything that is uncorrectable about the rs with a gs-r motor.
Old Sep 24, 2004 | 07:44 PM
worm696's Avatar
worm696
Originally Posted by Deagle
The RS uses the same parts as the LS for most things,
the rs is just a submodel of the ls
Old Sep 24, 2004 | 08:32 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
If you want to know for sure, open your passenger door and read the sticker that says GSR, RS OR GS. I think GSR 's may all start w/the same kind of vin # as well, depending on the yr.
Old Sep 30, 2004 | 05:15 AM
Deagle's Avatar
Deagle
Nüb
I don't think the GS-R subframe is different from the RS or LS, but, I know the Type-R is reenforced to cope with a thicker rear sway bar. If you want to put a stiffer rear sway bar on an RS/LS (I think the GS-R as well), you need to reenforce the points under the bushings where the sway bar attaches so it doesn't end up tearing out.
That also brings up the point of the RS with a GS-R motor/transmission being superior to a real GS-R because it doesn't have a moonroof. I wouldn't be surprised if that's true since the Type-R has thicker stampings in the pilar and roof area. G3s are known to be squeeky; their chassis aren't very stiff.
Old Sep 30, 2004 | 06:31 AM
LT's Avatar
LT
wowzers..lots of misleading info in here:
GSR/GS/LS/SE/RS all have 4-wheel disc brakes STANDARD! There are NO differences between subframes on these models. The GSR was equipped with a 24mm front sway bar, the submodels had a 22mm (94-7); 98-01 GSR submodels then upgraded to 24mm as well. GSR had 14mm rear whereas the 94-7 LS/RS/GS/SE coupes had 13mm (sedans had 14mm), then 98-01 ALL models (minus the ITR) upgraded to 14mm rears as well. There is NO difference in spring rates or dampener stiffness between the non-ITR models. The GSR did get a front strut bar STANDARD unlike the RS/LS/GS/SE models.
The RS does NOT have a stiffer chassis than the ITR, as the ITR has reinforcement in the roof, b-pillars, and the rear wheelwells and arch extensions were made thicker - including subframe reinforcement.
Brakes: same diameter rotors (front and back) among the non-ITR models.
94-5 GSR motors had a simple oil cooler equipped from the factory, 96+ GSR's did not.
Old Sep 30, 2004 | 09:41 AM
94GsArrr!'s Avatar
94GsArrr!
DOHC VTEC B18C1
coupe? not 3 door hatch?
Old Sep 30, 2004 | 11:10 AM
kidM0UA's Avatar
kidM0UA
and the ls is just a submodel of the gs/r
