What is a Bottle Neck?
Old May 28, 2004 | 01:22 PM
shhhhhgsr's Avatar
shhhhhgsr
Default What is a Bottle Neck?
What and where is the bottle neck? and does it come on every exhaust (stock & aftermarket)? if they come on the aftermarket ones, how much to fix?
Old May 28, 2004 | 07:39 PM
shivers's Avatar
shivers
Moderator Alumni
Bottlenecks occur when the diameter of the exhaust pipe decreases in certain areas ... this is most common before, after, and inside resonators and around flanges/joints. They are not common to every exhaust and generally the better the exhaust, the better the flow from little or no bottlenecks.
2005 s2000
Old May 28, 2004 | 07:52 PM
shhhhhgsr's Avatar
shhhhhgsr
thanks! can i get a stock size (2.25in) aftermarket catback?
Old May 29, 2004 | 06:47 AM
LT's Avatar
LT
The deer had to die!
yes, carsound makes them @ www.car-sound.com
Old May 29, 2004 | 10:23 AM
b00gers's Avatar
b00gers
"bottlenecks" arent specifically for exhausts pipes only. just think of bottlenecks as things that interupt the smooth flow of something.
for example. modding your car with an aftermarket intake and 2.5" exhaust and a free flowing muffler on the integra. then you go ahead and add some lumpy cams. the bottle neck will be the part that interupts that flow, which would be the header.
Old May 29, 2004 | 12:10 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
a bottleneck is when a bunch of gawkers slow down to look at an accident on the highway, or when there's one slow doofus working on an otherwise efficient assembly line.
Old May 29, 2004 | 02:16 PM
rgbpmp's Avatar
rgbpmp
Rubbernecker
Old May 29, 2004 | 08:04 PM
Kai's Avatar
Kai
Rotorphile.
In case it isn't quite clear from what the others have said:
A "bottleneck" is more of a concept, it's a point of restriction. Think of a bottle of beer and a mason jar of beer. Tip them both upside down, the bottle will take a while to empty while the mason jar dumps out all at once. Now you understand where the term comes from, and the restriction it implies.
Now lick the beer off the floor, realizing what an idiot you where to pour two entire beers out. :chuckles:
The term is generally used in a negitive sense, as in a "bottleneck" is a bad thing to have.
Old May 30, 2004 | 11:38 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
A bottlekneck is an expression, euphemism, analogy, etc. It's not an actual part.
Old Jun 1, 2004 | 09:38 AM
shhhhhgsr's Avatar
shhhhhgsr
ok ok ok ok i get it!!!! had the answer long ago and all i see is cola bottles and the same answer to my question...but thanks for all of the consistancy!!!(not complaining)
bbasso
17
May 3, 2004 08:19 PM
SuperStar19
7
Jan 31, 2004 08:56 PM
itsRaine
Oct 4, 2003 08:02 PM
92GSRhatchturbo
Sep 22, 2002 06:20 AM
StreetRacer69
Aug 5, 2002 10:01 AM
