FROZEN Ground Control Perches - ***HELP***
Old Nov 11, 2002 | 02:34 PM
nteg's Avatar
nteg
any recommendations on how to get that stripped bolt to turn or something productive?
Old Nov 11, 2002 | 04:14 PM
Taiwanze7's Avatar
Taiwanze7
one solution would be to take the whole damned thing out, and drill out the bolt, or get a bigger hex on it. they have the sharp indents, take a larger stanley screwdriver, angle it in the indents and hammer it a few times, that should jog it loose.
Old Nov 11, 2002 | 06:22 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Drilling out the bolt has been a solution advocated on other boards, and it works fine, it's just a hassle.
I'm not sure what other paths there are if you stripped the bolt though...
Shingo
Old Nov 12, 2002 | 10:15 PM
Taiwanze7's Avatar
Taiwanze7
I remember discussing w/ old skool domestic friends, and they've used different kits (I need to find out) but most of them consist of take a sharp phillips like screw driver...hammering into the nut and the twisting it out. However the catch is based on the material of the stripped screw/bolt. I'll try to find out more (late and I've got work tomorrow).
Old Nov 13, 2002 | 03:26 AM
pomansouth's Avatar
pomansouth
maby try an impact wrench. and im pretty sure anytype of greese will stay on there through a car wash as long as you smear it on there pretty well and dont leave it in clumps because clumps are bigger and catch more water and will fall off
Old Nov 13, 2002 | 05:27 AM
XSrcing's Avatar
XSrcing
coca-cola is an anti-rust compound.
Old Nov 13, 2002 | 01:32 PM
Deagle's Avatar
Deagle
Nüb
Coca-cola isn't an anti-rust compound. It's a rust remover because it has a pH of 3 from all the citric acid in it.
Old Nov 13, 2002 | 05:59 PM
stumpyf4's Avatar
stumpyf4
Heat up the screw with a propane torch and spray some penetrating oil on it. Repeat it a couple of times. The heat and added to penetrating oil will boil the oil in the threads hopefully allowing it to penetrate deeper.
Buy yourself some stainless screw and anti-seize compound and go to town after you get those babies out.
Old Nov 13, 2002 | 07:47 PM
XSrcing's Avatar
XSrcing
same difference.
Old Nov 13, 2002 | 07:50 PM
Deagle's Avatar
Deagle
Nüb
Aug 17, 2007 02:45 PM
themilman
Jan 17, 2007 09:51 PM
agent87
92+ Civic/EL & Del Sol
19
Apr 24, 2003 07:57 PM
Apr 15, 2003 11:13 AM
