indiglo gauges
Old Aug 6, 2002 | 07:42 AM
Chrgsr96's Avatar
Chrgsr96
Default indiglo gauges
k well i just got my indiglo gauges in yesterday and i've already got everything installed and hooked up except for the power wire. I grounded the ground wire to a screw that was back in where the gauges go but i have no clue as to what wire i should hook the power wire up to. I want the guages to come on when i turn on my parking lights so wouldn't i just hook the power wire up to the parking lights wire..which wire is the parking lights wire or should i hook it up to a different wire... Can anyone tell me what wire i have to hook this power wire up to because thats all i need to do and i'm done. Thanx
Old Aug 6, 2002 | 09:37 AM
Chrgsr96's Avatar
Chrgsr96
anyone know nething?
Old Aug 6, 2002 | 10:54 AM
Scimitar's Avatar
Scimitar
Hey,
Look at your fuse panel. There are five extra power lugs. One of them is on only when the key is turned to the on position (I think it is the fifth one). Use that for power. Use the Headlight switch lead, (you can find this on the dimmer, it is either black with red, or red with black, I can't remember) to be 12 volts positive to a standard 12 volt automotive relay. This relay should click, when you turn on your headlights. Now, hook the power from the fuse panel up to the normally open connection of the relay, and the power connection of the power inverter (supply, normally red, but 12 +) to the common connection of the relay. What will happen is every time you turn on your parking/head lights the relay will close connecting the 12 from your fuse panel to the power inverter. This has a couple good effects. Your indiglos will not flash when you chirp your alarm (because power only works if the key is on) so it will not burn out your power inverter. Also some people will use the power from the dimmer to power the inverter, but this will burn it out after a couple of months.
If you have any more questions hit me up with an email
Scimitar19@pacbell.net
Well, I hope that helps.
Peace,
Scimitar
Old Aug 6, 2002 | 04:34 PM
ChopstiX's Avatar
ChopstiX
Oh just hook it up to your dimmer.. Heres a guide from www.team-integra.net check it out. The website ownz!! heres the guide btw
http://www.team-integra.net/sections...p?ArticleID=84
Old Aug 7, 2002 | 12:29 PM
Chrgsr96's Avatar
Chrgsr96
ok i followed that guide on that site and it said to hook up the power cable to the dimmer power cable, a red and black wire.((the dimmer controller thats to the right of the steering wheel)) Well i did that and it still didn't work. Any clue as to whats wrong now? I thought maybe bad grounding but i took the ground wire and put it on something i knew for sure was good grounding and it still didn't work. I don't know what to do now someone help.
Old Aug 7, 2002 | 03:31 PM
rabican's Avatar
rabican
i forget what wire i put mine on but i didnt know so i just patched it into 1 and it was wrong then did it to another and it workd...i would suggest testing it out like i did...just make sure u fix the wire good and allz good
Old Aug 7, 2002 | 06:14 PM
ChopstiX's Avatar
ChopstiX
hrm.. did you try the last red wire.. when i opened up mine the order was from left to right.. red wire and then red/with black line, then the black. I hooked the red power to the very left red wire and then hook the other to ground. if that still dont work after you check out connections make sure it isnt faulty.
Old Aug 8, 2002 | 12:14 PM
Chrgsr96's Avatar
Chrgsr96
yea i decided last night to just straight up hook the guages up to my battery to see if they were faulty. I hooked them up and they lit up for like 5 seconds and then went out. They wouldn't light up again. So they're faulty. I sent them out today to the company and they're gonna replace them so i should be able to figure these things out when i get them back cause i think i had the right wire the last time its just they wouldn't light up cause they were faulty.
Old Aug 8, 2002 | 07:04 PM
ChopstiX's Avatar
ChopstiX
oh ok sorry to hear u got faulty stuff..
loodboi
92+ Civic/EL & Del Sol
26
Jan 14, 2003 03:08 AM
2000accordV6
Accord
Aug 24, 2002 09:50 AM
vtecaccord01
Accord
6
Aug 19, 2002 06:44 AM
2000accordV6
Aug 16, 2002 07:15 AM
pimpachu
Accord
5
Aug 6, 2002 08:09 PM
