Water ingestion
Old Feb 22, 2004 | 08:47 AM
bencallebaut's Avatar
bencallebaut
Default Water ingestion
Hi, I just installed my AEM cold air intake on my 94 tegra ls, last night after I installed it I went for a spin but it was raining, I floored it many times forgetting about water ingestion ( I was a little excited after installing it; it's my first mod), does anyone think I may have ingested water? Is there anyway to find out?
Also I am going to bye an AEM bypass valve, I dont get how to install it on my intake though, does anyone know?
Old Feb 22, 2004 | 09:51 AM
So.Cal_INTEGRA's Avatar
So.Cal_INTEGRA
Trust me you would know if water got sucked up.
And for the bypass valve, it only works if the filter is completly submerged in water.
Just dont be stupid when driving in the rain and your car will be fine, just keep your rpm's real low when going through a area with flooded water.
Old Feb 22, 2004 | 10:07 AM
bencallebaut
Also, when I installed it, the filter is slightly ( I mean very slightly) touching the splash guard... do you think that is going to be a problem?
Old Feb 23, 2004 | 05:41 PM
93Nteg's Avatar
93Nteg
not a big problom, but if you are a profectionist, go ahead and try to adjust the positioning of the intake, trust me its possable.
P.S.- you might want to wait on adjusting the intake until you get your bypass because if you adjust it wrong I've seen the hood scratch the finish a little if not perfect.
If your motor isn't making any disturbing noises trust me your fine. Just get that bypass on ASAP, just in case.
Bypass Installation
*mark the spot that you want it installed.(usually in the middle of the area after the third bend in the intake tube from the manifold connection.)
*measure the gap that the bypass will cause from the inside of the bypass.
*carefully mark were your 2 cuts on the intake tube will be to make up the diffence that the bypass will take up.(make sure that you mark on both the top and the bottom of the intake tube so as to keep the cut steight and level.)
*cut the tube in the 2 spots.(If you've done this right there should be a peice of the intake tube left over, dospose of it.)
*attach the bypass valve in the middle of the 2 halves of the intake piping.
*tighten it down.
*reinstall the intake.
And there you go.
puresport
CRX & Pre 92 Civic
4
Jun 29, 2003 07:37 PM
RaVen_CiviC
92+ Civic/EL & Del Sol
20
Jan 21, 2003 09:17 PM
Bogatyr
CRX & Pre 92 Civic
2
Jan 13, 2003 06:59 AM
REbornHONDAneer
Accord
9
Aug 18, 2002 04:22 PM
TheRooster
4
Jul 6, 2002 10:47 PM
