car washing dilema
Old Jan 21, 2003 | 11:47 AM
RaVen_CiviC's Avatar
RaVen_CiviC
CTR = Fun
Default car washing dilema
what do you do when you are washing your car and the water in the bucket freezes along with the water on the car?? i hate when the salt gets on my purdy black civic so ive been filling the bucket with really hot water and going from there...
Old Jan 21, 2003 | 12:23 PM
black beast's Avatar
black beast
there was this invention, like 3293948 years ago. its called fire/heat.
try using warn water.
Old Jan 21, 2003 | 12:31 PM
SeeCamGo's Avatar
SeeCamGo
LIGHTS Army Soldier
Yeah "warn" water is greaaaaaaat. :fawk:
Old Jan 21, 2003 | 12:33 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Warm water. HOT water freezes faster then cold water...werid.
Old Jan 21, 2003 | 12:54 PM
Tirod's Avatar
Tirod
just go through a touchless wash...
Old Jan 21, 2003 | 01:01 PM
SeeCamGo's Avatar
SeeCamGo
LIGHTS Army Soldier
NO!
Old Jan 21, 2003 | 02:11 PM
Hondaman's Avatar
Hondaman
Black Pearl
:squint:
Please explain this concept to me. I'm curious how it works...
Old Jan 21, 2003 | 02:19 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Originally posted by Hondaman
:squint:
I didn't believe this for the longest time, until I did the experiment. Stolen from the web:
You put two pails of water outside on a freezing day. One has hot water (95 degrees C) and the other has an equal amount of colder water (50 degrees C). Which freezes first? The hot water freezes first! Why?
It is commonly argued that the hot water will take some time to reach the initial temperature of the cold water, and then follow the same cooling curve. So it seems at first glance difficult to believe that the hot water freezes first. The answer lies mostly in evaporation. The effect is definitely real and can be duplicated in your own kitchen.
Every "proof" that hot water can't freeze faster assumes that the state of the water can be described by a single number. Remember that temperature is a function of position. There are also other factors besides temperature, such as motion of the water, gas content, etc. With these multiple parameters, any argument based on the hot water having to pass through the initial state of the cold water before reaching the freezing point will fall apart. The most important factor is evaporation.
The cooling of pails without lids is partly Newtonian and partly by evaporation of the contents. The proportions depend on the walls and on temperature. At sufficiently high temperatures evaporation is more important. If equal masses of water are taken at two starting temperatures, more rapid evaporation from the hotter one may diminish its mass enough to compensate for the greater temperature range it must cover to reach freezing. The mass lost when cooling is by evaporation is not negligible. In one experiment, water cooling from 100C lost 16% of its mass by 0C, and lost a further 12% on freezing, for a total loss of 26%.
The cooling effect of evaporation is twofold. First, mass is carried off so that less needs to be cooled from then on. Also, evaporation carries off the hottest molecules, lowering considerably the average kinetic energy of the molecules remaining. This is why "blowing on your soup" cools it. It encourages evaporation by removing the water vapor above the soup.
Thus experiment and theory agree that hot water freezes faster than cold for sufficiently high starting temperatures, if the cooling is by evaporation. Cooling in a wooden pail or barrel is mostly by evaporation. In fact, a wooden bucket of water starting at 100C would finish freezing in 90% of the time taken by an equal volume starting at room temperature. The folklore on this matter may well have started a century or more ago when wooden pails were usual. Considerable heat is transferred through the sides of metal pails, and evaporation no longer dominates the cooling, so the belief is unlikely to have started from correct observations after metal pails became common.
Old Jan 21, 2003 | 02:22 PM
94civicEX's Avatar
94civicEX
I got worms.
Just leave it dirty :dunno:.
99 Integra GSR
06 TSX
duck squad member #00003
Old Jan 21, 2003 | 03:38 PM
RaVen_CiviC
CTR = Fun
haha thanks for the advice
