My teggy is giving me some problems
Old Feb 9, 2004 | 07:00 PM
Hurrakaine's Avatar
Hurrakaine
Default My teggy is giving me some problems
First problem, is my car gives me a hard time when I try to shift. First it was 2nd gear, now its all five. I thought it was the syncros at first, but now I dont know for sure.
The second problem is a slight engine tick. When I first start it usually its cool, but when it warms up, you can hear this faint tick, and since I need to sell my car to start working on a supra turbo, its a little annoying. ANy help would be appreciated.
www.xanga.com/hurrakaine
www.xanga.com/fastimports
Old Feb 9, 2004 | 07:15 PM
slammed91-hatch's Avatar
slammed91-hatch
if your tranny is hard in all 5 gears it won't be synchros. try draining the tranny fluid and puting fresh in. ticking might be valves. when was the last time you had valve adjustment done?
Old Feb 10, 2004 | 10:34 PM
acuragal03's Avatar
acuragal03
i have the same clicking, i got it checked out. its just your valves(very common on hondas/acuras). Just get them torqued.
Old Feb 11, 2004 | 10:25 AM
OregonHusker's Avatar
OregonHusker
I had the same shifting problems that you described. I changed the transmission oil and the problem persisted. I then went to a mechanic and he told me to add a product called "equa torque" to the transmission oil. I did and within 2 weeks the shifting problem was gone and has been gone for about 3 months now.
Old Feb 11, 2004 | 11:42 AM
Tobra's Avatar
Tobra
If the hard shifting is the tranny fluid, you will notice a larger improvement using synthetic, but if you are selling, I would just use Honda fluid. Make sure you can get the fill plug off before you drain the tranny fluid. The ticking is probably valves, as the other guys say
Old Feb 11, 2004 | 04:46 PM
Hurrakaine's Avatar
Hurrakaine
Thanks guys I never had my valve adjusted,i will most def get that done. Today going to work, my driver side drive axle broke, i guess or came out. So I was stranded 2 minutes from my house, so it got towed to my mechanic
Old Feb 12, 2004 | 05:49 AM
acuragal03's Avatar
acuragal03
wow, sorry to hear that Well I guess now is the time to get the valves adjusted and to check out why shifting is so hard. Good luck.
Old Feb 17, 2004 | 12:42 AM
DaCatz8's Avatar
DaCatz8
Default Equa Torque - where do u get it?
Hey OregonHusker, I have this problem too. This product equa torque, where do i get it? And did u change the oil yourself? If so, how much equa torque did u put in the transmission oil? Do you have to just add it to the oil already in, or do u have to mix it before u put in the new oil. Any details of this is greatly appreciated. Thanks.
Old Feb 17, 2004 | 01:22 AM
Civic2Scooby's Avatar
Civic2Scooby
actually Honda MTF is recomended over sythetic....I used to run synthetic in mine and the gears ground mor than when I ran mobil one regular oil...the syth is almost too slippery for the gear box.
lx_rob
Accord
Feb 1, 2004 08:20 AM
kazi
News & Rumors Archives
9
Jul 9, 2003 06:29 PM
The411vm
Prelude
4
Jun 23, 2003 12:55 PM
Zols83
Accord
5
Jun 4, 2003 05:16 PM
SpoonFedEG
Engine Swaps, Tech & Tuning
7
Sep 4, 2002 09:19 AM
