2000 LS engine into a 92 Teg
Old Feb 6, 2004 | 04:15 PM
Reason's Avatar
Reason
Default 2000 LS engine into a 92 Teg
How easy is it to fit an LS engine from a 2000 Integra, into a 1992 Integra? Do I need different motor mounts and or axles? :thinking:
Old Feb 6, 2004 | 04:34 PM
slammed91-hatch's Avatar
slammed91-hatch
i think it should pretty much bolt in, but you need to convert either the motor down to obd 1, or the car to obd2. preferably to obd 1 since it's easier. i think the mounts you have should work. not sure about axles, but seems like they should work. shift linkage might be a little longer or shorter on one, but not sure.
Old Feb 6, 2004 | 07:27 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
You need to use the parts from the 92- axles,shift linkage,motor mounts,engine wiring harness,ECU.You will aslo have to convert the engine to obd1, which means you have to change the injectors and the distributor to obd1 (92-95 parts).
Old Feb 6, 2004 | 07:34 PM
Reason's Avatar
Reason
What is obd1 and obd2? :thinking:
Old Feb 6, 2004 | 08:04 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Let me see how I can best explain this...:thinking:...Its pretty much the the cars computer system (on board diagnostics) The obd1 system has less sensors than the obd2 system. They use different plugs so thats why I said you would have to use your stock engine harness and change the distributor and injectors on the 00 motor to obd1 parts from a 92-95 integra motor.
Old Feb 6, 2004 | 09:32 PM
RB's Avatar
RB
snitches get stitches
just to clarify...
b18a1 (RS, LS, GS) = 90-93 Integras. 90-91 = NO obd, 92-93 = obd1
b18b (RS, LS, LS-S, GS) = 94-01 Integras. 94-95 = obd1, 96-01 = obd2 (I think later models had a revised version of obd2, but don't quote me on that.)
Old Feb 6, 2004 | 09:41 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Originally Posted by RB
you're confusing civics with integras.
:thinking: What did I get confused? You do know that the distributor and injectors are the same right as long as they are both obd1, it doesn't matter if they came of the b18a or the b18b.
RaVen_CiviC
92+ Civic/EL & Del Sol
34
Sep 24, 2004 06:11 PM
AciDKinG95LS
11
Aug 15, 2003 07:45 PM
skeeterDX
Apr 5, 2003 09:16 PM
Tirod
News & Rumors Archives
31
Mar 3, 2003 05:13 PM
jaje
Jul 11, 2002 08:01 AM
