my timing is screwed
Old Jun 13, 2003 | 05:05 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
Default my timing is screwed
i just recently checked my timing and there are no markings when the light flashes so i tried adjusting my timing retard and advance and no matter which way i go there are no markings, could my timing be really advanced or really retarded to the point you cant see it on the pulley. a local speed shop installed my crower cam, and when they installed it the cam was set at 9' advance. but according to the cam card its supposed to be on an intake centerline of 106' if using the "lobe center" method. so right now my idle is kinda low sometimes like between 200-500 and sometimes its regular for a little while. my engine is a d16y8 auto and i do have a new IAC valve, cap, rotor, plugs, wires, ignition, clean filter and vacuum lines. what could the problem be? maybe the cam/ignition timing is off? what would you recommend i set the cam at and my timing at?
thanks
Old Jun 14, 2003 | 08:57 AM
crxb16er's Avatar
crxb16er
possibly everything is running fine, just turn up ur idle a bit to avoid it going too low and bogging.
Old Jun 14, 2003 | 12:33 PM
AwwsChwA's Avatar
AwwsChwA
Your timing is probably fine. The timing belt can't be off by more than about 2 teeth, cuz if it was you'd either have pistons hitting valves, or be extremely close to pistons hitting valves, in which case your car woudln't idle worth a damn. It would sputter, stall, and shake like crazy.
Old Jun 18, 2003 | 10:24 AM
jung4g's Avatar
jung4g
Asianalize your car
Wrong, your car won't run with it off by that much... it's a safety feature...
The timing is probably ok, my first guess is that you don't have the timing light attached to the proper cylinder... Cars won't really run much if the timing is off by all that much... raise the idle to around 800 and then check your #1 cylinder and then the timing...
Jung
Old Jun 18, 2003 | 10:27 AM
NeverBX's Avatar
NeverBX
Jung
i do check timing with the #1 cylinder, idle was at 800 when i checked it.
Old Jun 22, 2003 | 05:02 PM
jkjk's Avatar
jkjk
Don't you have to jump the service connector inside the car under the dash on the passenger side to get an accurate reading?
Old Jun 22, 2003 | 07:30 PM
NeverBX's Avatar
NeverBX
do you have to? can anyone confirm this? ive never done that before.
Old Jun 22, 2003 | 08:24 PM
PHiZ's Avatar
PHiZ
BOOST GOD
haha, yup otherwise your ECU is pulling timing dynamically, jumping the timing connector (CEL code connector). Makes the ECU use static timing.
Got it?
The jumper is also used to get the CEL to flash the codes, do a search for that, to find a description of the jumper. Maybe I'll take a picture in a couple of days.
-PHiZ
Old Jun 22, 2003 | 08:55 PM
NeverBX's Avatar
NeverBX
lol i use the jumper to pull codes but just didnt know i had to jump it before i check the timing.
Old Jun 23, 2003 | 06:58 AM
PHiZ's Avatar
PHiZ
BOOST GOD
dude, go back to working on camaro's...
hahah, just ****ing with ya, let us know how it goes.
It's cool that you know how to check timing, but it's just a tad different on the hondas, heheh.
Aren't there two styles of timing guns, which are you using?
-PHiZ
