ACT vs Exedy
Old Mar 16, 2006 | 10:55 AM
rugsr's Avatar
rugsr
How do my taillights look
Default ACT vs Exedy
Buying a flywheel within a few days and ive been talking to some sponsers on which is a better flywheel.
Chromeolly is the way to go from what i hear BUT from some people i hear EXEDY Flywheel is better then ACTs Flywheel.
Exedy Racing Flywheel
and
ACT Streetlite 12.5
Im going with the ACT XTSS clutch........can i only use a act flywheel? i can use an exedy right?
Which flywheel do u think is better?
Old Mar 16, 2006 | 11:54 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
ACT > Exedy. End of story.
You can use whatever flywheel you want, but the ACT is probably better.
Old Mar 16, 2006 | 12:08 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Undoubedly! :yes:
You'll be happy with the XTSS. It's a little harsh at first, but it grabs like a mother and very low on the pedal. Nice clutch choice.
Old Mar 16, 2006 | 05:44 PM
1turbodc2's Avatar
1turbodc2
got boost?
agreed, ACT is the shit, i would go wiht that like some of the other guyz have stated!
Old Mar 16, 2006 | 07:12 PM
IntegraGSR12's Avatar
IntegraGSR12
I am going to order the AI4-XTR6 ACT clutch next friday. How do you guys feel about this model clutch will I be happy with it?
Old Mar 16, 2006 | 07:16 PM
westcoaststyle
Prepare to have your teeth rattled out. I had that only because of necessity. Making 457 whp / ~320 wtq required that I get it because I was destroying the XTSS quickly.
The R6 is very very harsh as it is an unsprung 6-puck disc. I daily drove my car, but if you don't HAVE to get that clutch, you really shouldn't. It's a fairly hard clutch to drive on a daily driver. :happysad:
Old Mar 16, 2006 | 07:20 PM
IntegraGSR12
I have 250whp around 170ftlbs of torque Which clutch that act makes do you reccomend. I would like to get the extreme pressure plate though because I am running turbo and I am going to build the engine with an lsvtec fully built in about 9 months.
Old Mar 16, 2006 | 07:22 PM
westcoaststyle
The XT pressure plate is a must. If you look at the ACT site (www.advancedclutch.com) they list the torque parameters for each kit. I suggest you look there and get what you think will work for you now, and after future power is made - cause you know you won't stop here.
Don't overdo it. I think the SS will work just fine for your setup.
Old Mar 16, 2006 | 07:34 PM
IntegraGSR12
aight then Ill go with the xtss kit. Thanks
Old Mar 16, 2006 | 07:40 PM
westcoaststyle
np
