i hate philips head screws
Old Feb 8, 2005 | 07:49 PM
89civicSiR's Avatar
89civicSiR
thats right im a NOOB!
Default i hate philips head screws
ok here is what the deal is. i have a 89 civic hatch and i will spare you the long story of how my stud broke but i went to take off the rotor to replace the studs and those two screws that hold on the rotor will absolutely not come off they even started stripping. i know i could probably take it somewhere and let them do their magic but i would rather "do it myself" so my question to you is, is there any way to get those damn screws out anything will help
thanks
Old Feb 8, 2005 | 08:02 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Did you try using an impact hammer? They sell them for about $25 and they will remove those screws. If that doesn't work, you will have to drill them out. You could also try using a die grinder to drill a larger slot in the screw and using a larger flat head to remove them. Good luck though.
Old Feb 8, 2005 | 08:09 PM
12yearhondatech's Avatar
12yearhondatech
yes the screws can be removed try soaking them with wd-40 then use a center punch to try to brake the screws loose by hitting the punch with the hammer put the punch at an angle and try to make the screw turn counter clock wise. Or you could just drill off the heads of the screws, they are only there to hold the rotor in place when the wheel is off, you dont need them,or just go to Sears and get a stripped screw removeal tool kit.
Old Feb 9, 2005 | 07:48 AM
89civicSiR's Avatar
89civicSiR
thanks i think i will try drilling them out, i could probably get those srews at almost any hardware store or auto store right?
Old Feb 9, 2005 | 09:32 PM
Provocateur
On permanent hiatus
Get them at the dealer. They are like $.70 a piece. You could probably go without them considering the pressure of the tire and the lug nuts will be more than enough to hold the rotor on.
Old Feb 9, 2005 | 10:19 PM
hakjai's Avatar
hakjai
http://www.sears.com/sr/javasr/produ...id=00947641000
try that before drilling into the screw
Old Feb 9, 2005 | 11:24 PM
Provocateur
On permanent hiatus
I have that same tool for when I do my rotors. Haven't used it yet but my rotors are in desperate need of changing.
Old Feb 10, 2005 | 11:18 AM
sophal's Avatar
sophal
Mr. Lover
it's called a impact screw driver...
Old Feb 10, 2005 | 11:19 AM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
I hate flat-head screws...the driver always slips off
Old Feb 10, 2005 | 11:31 AM
fjm1's Avatar
fjm1
G35
Impact drivers are great! Sears also has a bit set for damaged phillips heads. EZ outs I think they're called.....
Drilling is last resort.
