i hate philips head screws
Old Feb 12, 2005 | 12:20 PM
raiden571's Avatar
raiden571
turning u inside out
wack them with a rubber mallet
Old Feb 16, 2005 | 06:54 AM
'93TurboD's Avatar
'93TurboD
5-finger discount :rick:
A Rubber, Plastic or dead blow hammer will do the trick, or put a block of wood inbetween and hammer away. When U put it all back together make sure your hub is clean and smooth and put some anti-seizing compound on it. That should keep it from seizing on again.
The screws are there for the factory, so when the cars are moving along the assembly line the rotors don't fall off. Just put a lug nut on during reassembly to keep the rotor from flopping around.
Old Feb 16, 2005 | 11:25 AM
93EXaccord's Avatar
93EXaccord
Engines hate me!
o dont you love accords... like he siad we just used a cutting torch, plane and simple.
Last edited by 93EXaccord; Feb 16, 2005 at 11:28 AM. Reason: eric (raiden) beat me to it
