For the Guru's:crx na b20 ?'s head work or bottom end?
91 crx si
b20b2
65mm intake manifold
4-1 headers
2.5" catback exhaust
integra axles
ls ecu
stage 3 act clutch
7.5lb fidanza flywheel
aem fuel rail
aem fuel pres. regulator
msd ignition system w/8.5mm wires
cold air intake
underdrive pulley
now, i have 3 questions:
1. I NEED TO FIND a 92-93 gsr tranny cable 5 spd,
or a 89-91 crx sir 1st gen b16 cable 5spd
or the cars going no where, where can i find one?
which should i do first?:
2.head work
b16 head
403 cams
high rev valve springs
titanium retainers
larger valves (what mm?)
larger injectors (whatmm?)
comp. system? (who and what)
adj. cam gears
stage 2 port and polish
3.bottom end
10.4:1 pistons (w/ proper valve clearance)
forged rods
forged crank
resleeve the b20 for longevity
high capacity oil pump
high pressure fuel pump
(both cost at least a grand, so which should be done first?)
3. does anyone forsee any problems with the current set up and/or options 1, and 2? or know where i can get one of the short ratio trannys? or know where to get a hydro converstion kit?
thank you for your import!!!
b20b2
4-1 headers
integra axles
ls ecu
stage 3 act clutch
aem fuel rail
cold air intake
underdrive pulley
2.head work
b16 head
403 cams
titanium retainers
adj. cam gears
3.bottom end
forged rods
forged crank
Sounds like you just went and bought all the parts available at your local ricery. You need to decide WTF you're going to do with your car before you move on, because there's no logical next step. You've already spent at least a thousand dollars on useless parts.
The b16 head will suck with the b20's compression, and the built b20 bottom end will just plain suck.
every part i bought is perfectly matched up for the engine, so no matter what head:b16,b18,gsr,type r, or stock b20, it all fits. with the part about choice 1 and , i will do both, and having 10.4:1 compression before the b16 swap is done, means that once the crvtec conversion is done, then the setup will be optimal. i just wanted to know which one to do first.
and the venom intake is soon replaced with a 65mm type r inspired manifold.
"they misunderestimated me." --------Pres. George W. Bush -----------
The AEM fuel rail isn't doing you any good. Same with the MSD ignition, venom manifold, and underdrive pulleys.
Doing both at the same time is by far the best idea. Doing this twice means pulling your head twice, which means two headgaskets and two sets of head bolts, plus a lot of wasted oil, coolant, and spare time. You don't need a forged crank, or resleeving if you're staying NA. Plus, your fuel pump isn't anywhere near your bottom end. That brings you to rods, pistons, and a VTEC oil pump. Not that much additional cash, and money you can easily make selling the useless stuff if you're lucky and your head comes with an intake manifold.
