vacuum/idle situation on ls swap
I have a obd0 ls motor in my 91 civic si hatch. It's in and starts, but it runs weird. The idle bounces in rpm like a constant steady bounce up and down. I get a code 14, which is eacv. How do i fix this. I pulled the eacv off to check it out and it didn't appear to be clogged or anything like that. Someone please help, this is all that's holding me back from getting my new swapped hatch on the streets.
with the car running and idling weird. removed the connector from the IACV. If the the idle levels off, you have found your problem. Remove the IACV and clean it as stated above.
You can also replace the IACV. From honda it's not the cheapest thing, but you can find used ones on the web easily.
www.sohfast.com
www.sohfast.com
sweet, my e-mail is bubbiemellum@yahoo.com. Let me know if you can send it. I will pay shipping of course. also, i have tried unplugging the wires to it while it's running, it makes no difference.
alright, i took the eacv off of the intake manifold and started the car, it definetely runs weird with it off. I don't know if this means anything. also will someone explain what the eacv does? I thought i had an idea, but i didn't know that coolant went through it, now i'm way confused on what this even does.
95integrajdmh22
Engine Swaps, Tech & Tuning
2
Feb 27, 2004 04:42 PM
