computer scanner WTF!!
Old Jan 10, 2004 | 03:55 PM
ShastSmae's Avatar
ShastSmae
Default computer scanner WTF!!
so i call like a million acura dealerships and nobody can tell me where the fuk the obd computer scanner plugs into. one guy said i cant plug it in. i find this hard to believe. anyway my buddy has a scanner and i want to check my codes if there are any. where the hell is the damn outlet??
Old Jan 10, 2004 | 05:00 PM
LT's Avatar
LT
The deer had to die!
looking into the engine bay, there is a harness on the right side, by the clutch master cylinder. there you will see the outlet (has a plastic plate covering the pins)
Old Jan 10, 2004 | 05:03 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
:thinking: Are you sure its there? My 97 LS had it under the dash h:
Old Jan 10, 2004 | 05:06 PM
LT's Avatar
LT
whoops! i'm thinking engine diagnostic plug!
yea the computer scanner is located under the dash, near the passenger kick-panel. it'll be in a green, plastic harness.
Old Jan 10, 2004 | 08:04 PM
worleybot's Avatar
worleybot
part time tech
you don't need a scanner for checking any codes on a honda or acura. Look under the dash by the glove box there should be a two wire connector tucked up there some where just put a jumper wire inbetween those two connectors and turn on the key. If there are any engine codes stored the CEL will start flashing count the long and short flashes the long ones will be the first digit and the short ones will be the last digit if there is more than one code stored it will give them sequentially and keep repeating them until you pull the jumper. If the check engine light comes on and stays on then there are no codes and the system is fine. Good Luck
Old Jan 10, 2004 | 09:31 PM
ShastSmae's Avatar
ShastSmae
cant i plug in the scanner in anywhere? most cars have the plug under the dash by your knees.
Old Jan 11, 2004 | 06:55 PM
worleybot's Avatar
worleybot
part time tech
Honda doesn't have the plug there it is located on the passenger side under the dash by the heater controls. It is kind of hard to locate if you don't know what you are looking for. And like I said earlier you don't need the DTC connector on a honda or acura because they have the two wire connector that you can jump and it will give you the codes that are stored. OBD II on the other hand is more specific because they have general codes that everybody uses and then manufacturer specific codes that you need a scanner for but on OBD I you really don't need a scanner for a honda or acura.
Old Jan 11, 2004 | 11:11 PM
ShastSmae's Avatar
ShastSmae
i dont quite understand . on the pass side by the kik panel i saw 2 plugs going int a green rubber thing now i take those plugs and stick a wire from where to where and how do i tell the codes from just a flashing light???
Old Jan 12, 2004 | 01:21 AM
sekongen's Avatar
sekongen
Look online or in a Haynes manual. The DTC'S should be listed in the manual if not on the net. I actualy heard odb2 computers dont use the flashing light method. Not sure though. Good luck
Old Jan 12, 2004 | 08:03 AM
worleybot's Avatar
worleybot
part time tech
You have found the right harness and if I remember correctly there is a two wire and a three wire harness. Jump the two wire harness with a jumper wire and turn you ignition to on. If there are any codes stored the CEL will start blinking you have to count the flashes. Long flashes are first digit and short flashes are second digit Example two long and 1 short flash is code 21 just make sure you count correctly because if you don't you might be trying to fix something that isn't broke. And yes OBD II in most makes and models doesn't use flash codes but honda and acura still do but the problem is that is will give you a say code 31 but that could be two different OBD II codes for the same sensor just different problems. So the flash codes for an OBD II will get you in the right direction but you need a scanner to narrow it down. Hope this helps
