Pulling transaxle ('92 Civic)
Old Jul 19, 2002 | 11:48 AM
bmwguy's Avatar
bmwguy
Default Pulling transaxle ('92 Civic)
I should have asked this question two days ago, but can you pull the transaxle out without disconnecting the right side A-arm on the suspension? I didn't try it that way, I just looked at the clearances and figured I had to allow more room for the axle to move so I unbolted the A-arm from the chassis. The transaxle came right out, but I was curious about how I did it.
After working on a couple of these Hondas, I'm finding them fairly easy to deal with.
Old Jul 19, 2002 | 01:48 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
It mainly depends on the car, and how much trouble you want to deal with as far as room/manipulation of the axle removed versus attached to the A-arm. Normally when I pull an axle it's to replace it, so I couldn't rightly tell you how often it works, I just know that on some of the cars you can get away with unbolting things as a unit to get enough room to pull the axle out of the differential.
:thumbup: Honda's aren't hard to work on, now Jaguar's, MG's, and select toyotas... that's another story [See, I was even nice and left BMW out of my PITA list , lol]
-Harry
AIM: NDcissive
Old Jul 20, 2002 | 10:15 AM
bmwguy's Avatar
bmwguy
Yeah, but you probably figured I already knew that.
Thanks for the reply. I got the seal and clutch replaced this morning and got it back together. The way I dealt with the axle was to unbolt the A-arm where it attaches to the underside of the chassis and leave everything else together, then I just pulled the transaxle case away from the motor and the axle and suspension moved with it as one. Worked great.
Dan
Old Jul 20, 2002 | 12:59 PM
1stGenCRXer
Yeah, that's the way I've done it before now that I think about it, the upper shock mounts normally give enough to open up some room.
Salmon Ella
92+ Civic/EL & Del Sol
May 31, 2007 08:05 AM
Oldkid
4
Feb 10, 2007 03:40 PM
eNoble
Accord
3
Sep 3, 2004 01:54 PM
Ross
6
Aug 27, 2004 06:24 AM
alongtheroad
8
Aug 2, 2004 09:32 AM
