CRX map sensor upgrade
Old Feb 21, 2003 | 10:11 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default CRX map sensor upgrade
my friend has a 89 crx si with D16a6 engine. it doesn't have vtec, so if he wants to upgrade the map sensor... which ones does he need to get? cuz there are a lot of them on ebay and i would like to know which ones will fit and which ones won't. also, can he fit the map sensor from a civic ex with vtec?
Old Feb 21, 2003 | 11:28 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Why does he need to upgrade his MAP sensor? If his MAP is dead, then he should just get a new/different OEM one. If he wants a MAP sensor that reads a wider range of pressure for tuning with a standalone, then he should get a GM 3BAR MAP, which looks like this:
If he's N/A, and his MAP sensor isn't malfunctioning, there's no reason to replace it. If it is malfunctioning, and he wants one that will bolt up to the stock location on the firewall, then a Civic MAP wouldn't be the best choice, since it attaches to the top of the throttle body.
Old Feb 21, 2003 | 12:02 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
actually, he is currently running NA. but he wants to change his map sensor to increase the mapping for fuel and air. he will be upgrading his fpr soon and adding this new map will help out.
Old Feb 21, 2003 | 02:12 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
"Upgrading" his MAP sensor will not have any effect on his fuel map. Adding an FPR does not necessitate a new MAP sensor. The only reason to swap MAP sensors is 1)if your existing MAP sensor is broken or 2)if you need a MAP sensor that can read more than 10-12 pounds of boost. If your friend is N/A, and his MAP sensor is functioning properly, there is no reason to get a new one. If he thinks it'll "increase the mapping for fuel and air", then let him get one, it won't hurt my feelings. It also won't yield any benefit.
Old Feb 21, 2003 | 06:58 PM
kerokeron's Avatar
kerokeron
Default thanks
wella tokyo racer,, thanks for asking a question for me!
Old Feb 22, 2003 | 09:35 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Is he running a forced induction motor with more than 1 bar of boost? Because otherwise the stock MAP sensor is fine, and the stock ECU goes into a limp mode if it senses boost anyway.
I see no reason to "upgrade" the sensor.
Old Feb 23, 2003 | 02:33 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default Re: thanks
tomo... u bastard... u should've posted urself... haha. anyway, it's all good... so now u know. if you have questions, just ask the forum or ask inspyrl for any technical questions... he's the man!!!
ruey
