which built is faster ???
Have fun trying to run 20lbs and a 50 shot on a stock motor and getting it to last more than half a pass down the track.
Originally posted by VtecApprentice
Hi everyone
and issit difficult to tune a compression ratio 12:1 engine if its feed with 98 octane level pump gas ? ? ? ? ? and is that compression ratio too high to run 100 wet shot ? ? ?
Hi everyone
As for nitrous, listen to everyone when they say to go with a direct port kit above 75. I have seen what can and usually does happen to a car running a fogger system above 75.
I find that nitrous cars which pass as fast as turbo cars, don't usually mph as high. Also, I double checked, it wasn't sleeved, it was BlockGuarded, other than that, internals were stock, and other than the turbo setup, some cam gears, and stage 4 hondata, everything appeared to be stock. A pretty proud tuner claim for an 11 second car!
I thought a wet system was when each cylinder had it's own nitrous injector and a dry system was when a single injector was mut on the intake tube. My question is: What's the difference between a wet system and a directport system?? thanks
Dry kit - nozzle in intake tube spraying only nitrous
Single fogger wet kit - nozzle in intake tube spraying nitrous and fuel "fog"
Direct port kit - each intake runner has it's own nozzle spraying fuel and nitrous "fog"
