Engine swap
Dec 17, 2006 | 01:58 PM
Engine swap
Hi to every one.
I have a b16 eg and i am thinking of doing b18c4 coversion with itr rods and pistons with double valve springs with skunk2 stage 2 cams.
Dose anyone know what the compressoin ratio will be, and what the pros and cons of this type of swap and any tips would be most gratefull.
(Just to let you know this is the first time for me to do any type of engin swap)
Dec 17, 2006 | 02:00 PM
compression would be 11-11.5:1.
pros - nice bump in power and torque if tuned properly
cons - blown motor if not tuned properly, headaches if you dont know what you're doing
Dec 17, 2006 | 02:19 PM
Quote:
Originally Posted by
Snoopy
Do you mean if the timing is not tuned properly or is there other causes to pay extra attension to.
And what type of power would i be expecting (i assume 200-210bhp)
Dec 17, 2006 | 05:46 PM
fuel and ignition timing must be properly tuned to keep your af ratios in check.
Dec 18, 2006 | 04:27 AM
Snoopy
Would a standard itr map be ok. then fine tune af ratio.
Dec 18, 2006 | 07:29 AM
as long as you only use the it basemap to get to a tuner
Dec 18, 2006 | 09:45 AM
Snoopy
I am picking up some itr pistons and rods tonight
they are out of a 98 or 99 dc2 and i will be getting new rings and bearings. Will used pistons with new rings work fine?
Thanks for your help.
Dec 18, 2006 | 10:09 AM
as long as there is no scoring on the skirts or cracked ringlands you can reuse them.
Dec 18, 2006 | 11:42 AM
Dec 18, 2006 | 02:08 PM
18crx
get honda bearings only
I want to get honda pistons rings as well, but i haven't priced them yet.
What size rings would i need?
And will i need itr injectors? or will the standard b18c4 be ok? I will be having a 9k rpm limiter
