Engine swap
What do you think of these gears with a 4.9 fd.
Final Gear 4.900................RPM(shiftpoint..............MPH.............RPM Drop
1st Gear Ratio 3.230............9,000..........................39.66
2nd Gear Ratio 2.105............9,000...........................60.86...............5,865
3rd Gear Ratio 1.458............9,000...........................87.87................6,234
4th Gear Ratio 1.107............9,000..........................115.73...............6,833
5th Gear Ratio 0.848............9,000..........................151.07................6,894
that'll give you nice acceleration but your cruising rpm's are going to suck
play around with this gear ratio calculator: http://www.fatboyraceworks.com/gears/
I cant seem to find any info for a ukdm s9b gearbox
Dose anyone know of any websites that list the ukdm s9b gear ratios.
Because i am not sure if it has the 4.2 or the 4.4 FD(or it might have something els) some people say it is 4.2 and some say its 4.4
Any info will be most gratefull.
After hours and hours of searching i have found this http://joooe.webhs.org/vti/specs.html
And it had to be rubbish news i have got a 4.266FD
