legal or illegal???
Old Dec 27, 2006 | 08:36 AM
SHUA619CIVICSI's Avatar
SHUA619CIVICSI
1991 CIVIC SI
Originally Posted by 2001TEGGSR
Wayyy of Topic, but I didn't notice anybody flaming you for a lack of knowledge. Just keep all input related to the Thread Title. If you have questions, start your own thread. This board is here to help you and everybody else accomplish there goals. If you want to be childish and bitch people out, do it in PM's, the basement, or HT.
I'm not one to talk because my grammar is horrible, but at least try to word your questions better if you want a realistic response. Its very hard to understand what you are trying to say. It gives people a headache, and most will not even attempt to make sense of it.
K THANKS 4 UR IN PUT WELL TAKEN
Old Dec 27, 2006 | 04:04 PM
htech1982's Avatar
htech1982
Default legal swap
im not to sure on ca. laws but i am emissions insp. cert. hear in pa. to answer your question if the car started out obd2 then it needs to stay that way. there are readieness codes that have to be read in order to pass electronic emi. if you use a sniffer as part of the insp. as long as the cat is working properly and your engine is running correctly it will pass. now if your motor is obd1 then you will probebly only have to do the visiual insp and tail pipe sniffer. so if the swap is done right and it is obd one you should have no problems.
Old Dec 27, 2006 | 07:22 PM
SHUA619CIVICSI
1991 CIVIC SI
my hatch is obd-o and im not shure if the b16a is obd-1 or obd-2 so ill see i talked 2 a inspector 2day and he said as long as i have all the sensors and lil bs they pick at like carb stickers ect. but we will see thanxs 4 ur in put ne more info about it let me know thankxz
Old Dec 27, 2006 | 11:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
This is true. As far as I know, any legitimate swap will pass as long as the engine is of the same year or newer, the engine is going into the same chassis type as the donor it came out of (i.e. no CRV motor because it is from a light truck), and all the emission equipment is in place and CA CARB compliant.
Assuming you do the swap correctly and have all the same sensors hooked up that were hooked up pre-swap, you shouldn't have any problem getting that engine BAR'ed.
Old Dec 28, 2006 | 07:40 AM
SHUA619CIVICSI
1991 CIVIC SI
cool thankz he the inspector said that after the swap i need 2 get it checked out 2 make shure it was done wright. than the person inspecting it will put his sticker on it than the somg people will go of of his sticker and not have 2 check everything them self.
