Cel 20 (eld)??
Old Sep 24, 2002 | 08:37 PM
pinoyboi's Avatar
pinoyboi
Default Cel 20 (eld)??
how can i fix this porblem and wht is it ??
Old Sep 24, 2002 | 09:46 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Electrical Load Detector is built into your main fuse box(underhood), and will usually throw a code if there's a short or blown fuse somewhere. When I had an ELD code, it was my alternator/VSS fuse that was out. I would check all your fuses, both underhood and underdash, as a first step. Use an electrical tester.
Old Sep 24, 2002 | 10:39 PM
Trickturn's Avatar
Trickturn
Balls or just crazy...
ITS A PITA!!!!!!!!!!! THATS WHAT IT IS!!
Im going through it right now.
Pete
Old Sep 28, 2002 | 08:53 PM
3gludeh22a's Avatar
3gludeh22a
Pete
PITA????? Whats that?? Im having the same trouble code in my car (88 prelude H22 Swap)
My headlights were working fine before i dropped my car off to get the swap done..Ever since ive had it back my left headlight goes down when i turn the left blinker on, and it blinks really fast. But the right is fine...can anybody help??? (please)
Old Sep 29, 2002 | 08:57 PM
Trickturn's Avatar
Trickturn
PITA = pain in the ass
My problem was the ground that connects to the thermostat housing. I thought my friend hooked up that & he thought I hooked it up.
So 4 hours later & going thru the Helms manual circuit by circuit, we finally find the problem. Damn some G151 ground (Thermo ground).
ELD is connected to just about every damn circuit in the car. When I have an ELD code, I cringe cuz it is the most feared by people who hate doing electrical troubleshooting.
First thing to check are all your fuses, then check your alternator as the ELD prime function is to measure the charging of the battery & keep the alternator from overdoing it.
After that, check the continuity from ELD wire to ECU. After that, make sure your ecu is good. If those check out ok, then start eliminating circuits until you find the problem.
If you have power to some grounds, check your ground circuits first instead of your power circuits, it could have saved me some time.
Pete
WantingInfo.
CRX & Pre 92 Civic
Dec 10, 2005 04:10 PM
ocliffie
Accord
Jan 3, 2005 08:42 AM
ErikGG
92+ Civic/EL & Del Sol
6
Oct 31, 2004 07:27 AM
00BlackTypeR
Engine Swaps, Tech & Tuning
Mar 25, 2004 03:14 PM
