Building a turbo B18b1
Old Jun 14, 2006 | 11:47 AM
ArsonistsMind's Avatar
ArsonistsMind
ArsonistsMind
yeah thats what i want the girdle for, you ever here of the guy i think its on honda swap that made his own block filler with epoxy? i think his name was hotrex, he used salt and some liquid aluminum epoxy to make his block closed deck...you think that would work to stiffen it up, for more boost?
Old Jun 14, 2006 | 11:50 AM
ArsonistsMind
ArsonistsMind
heres the link i was talking about
www.hondaswap.com/forums/ lofiversion/index.php/t63886.html
at the time i posted this it seems like the website is undergoing maintenance
Old Jun 14, 2006 | 04:43 PM
Snoopy's Avatar
Snoopy
been there done that
dont ghetto rig something as important as that. if you're so concerned, sleeve the block and you'll know its good to go. as for the girdle, golden eagle and other companies make girdle kits which would be a better solution to taking one off a b18c. installing the oil squirters is not going to be easy. you'll have to drill into an oil passage, tap it, then install them. and you still might have to bend them a little to clear the longer stroke of the b18a/b. just upgrade the pistons and rods and you wont need them.
and since noone's mentioned it yet....
vtech = phone company
vtec = honda's variable valve timing and electronice lift control
Old Jun 14, 2006 | 06:08 PM
5thgen's Avatar
5thgen
300 whp is around the limit you want to stay around on most b series motors. You can do it with a bone stock LS motor....if you do happen to have the head off though, get some arp head studs while its open.
You don't want to base a motor's strength on psi...instead base it on how much power it is pushing.
And stock for stock a vtec head will outperform any ls head.
Old Jun 15, 2006 | 06:09 PM
VTECNLUDE's Avatar
VTECNLUDE
I beg to differ. theres plenty of people making 300+ reliably on honda's. My own car made 300hp at 10.5psi. my gf's gsr made 327 at 11psi, my friends stock ls made 307hp at 13.5psi. and what might seem like a shocker...my friends single cam made 273hp at 12.5psi. as long as the engine is heatlhy, its all in the tune.
Old Jun 15, 2006 | 06:18 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by Iso187
Watch your stock bottom end too. Stock block boost limit is about 11 psi. I wouldnt go much more than 8, 10 MAX!
Where do you get your incredible misinformation?
11 psi is not the same thing on every turbo.
Old Jun 15, 2006 | 06:59 PM
5thgen's Avatar
5thgen
was just saying its a good rule of thumb. I personally run 14-15psi with a 57trim on my ls (most likely around 300whp).
and by the way I said *around* 300....I know they can make more stock.
Old Jun 16, 2006 | 05:03 AM
ArsonistsMind
ArsonistsMind
Hey thanx all great information
Old Jun 16, 2006 | 08:56 AM
dubcac's Avatar
dubcac
I
1. The block girdle from a GSR has to be machined to fit on the LS.
2. A VTEC head would make a good amount of power over your LS head.
3. It's VTEC, not VTECH
4. Crower makes cams, I don't know about Crowler
5. In terms of power on a stock block, 300whp is *about* as high as you want to go. Sure, VTECNLUDE posted two examples of people making over 300whp reliably, but not much. Anything higher than that starts to compromise the strength of the rods. The tune can only do so much. Once you start making a certain amount of power stresses on the internal components get close to their respective limits...preventing detonation by having a good tune won't help this.
Old Jun 16, 2006 | 05:59 PM
ArsonistsMind
ArsonistsMind
Wow you guys are really tempermental about your typos....sorry
