Building a turbo B18b1
Old Jun 14, 2006 | 05:48 AM
ArsonistsMind's Avatar
ArsonistsMind
ArsonistsMind
Default Building a turbo B18b1
I was wondering if you could take the girdle and under piston oil squirters from a vtech engine and put that on a non vtech block, also would a vtech head or a non vtech head be best for a turbo set up.... i am not really looking for big numbers around 300hp but still would like decent gas mileage...well the best i could for a 300hp turbo four banger
Old Jun 14, 2006 | 10:39 AM
onesuperm3's Avatar
onesuperm3
300hp is a big number on a honda
Old Jun 14, 2006 | 10:49 AM
Iso187's Avatar
Iso187
Just doing research on the web, i have read of people bolting on RevHard turbo kits with Crowler cams achieving 326hp to the wheels. And from what i have read and understand, the LS head would be better, i could be wrong though. I have read of devices (Phantom Grip) for boosted vtec cars that actuall elliminate the lobe advancing so that you only run on 1 or 2 of the 3 lobes. About the oil squirters, i dont know. If it would work i would like to install squirters on my B.
ArsonistsMind
ArsonistsMind
not with proper internals and a turbo...besides horsepower wasnt really my question i threw that figure out there...i just want to know if those pieces will fit on a non-vtech block or should i just chuck out the extra cash and get a vtech block
Old Jun 14, 2006 | 10:50 AM
ArsonistsMind
ArsonistsMind
any info on the girdle cap?
Old Jun 14, 2006 | 10:53 AM
ArsonistsMind
ArsonistsMind
i though the ls head would be better cause it has less overlap, which would make the engine fill with boost quicker
Old Jun 14, 2006 | 10:56 AM
Iso187's Avatar
Iso187
About the Girdle... i dont see why it wouldnt fit the b18a/b block. I would rotate the crank to make sure of clearences after installation. I plan on bolting a girdle on my built block. At the very most possible machine work or a bit of gringing. I dont know about the oil squirters though. If you find out, let me know.
Old Jun 14, 2006 | 11:03 AM
ArsonistsMind
ArsonistsMind
yeah man no doubt
Old Jun 14, 2006 | 11:06 AM
Iso187's Avatar
Iso187
My 2 on the choice of heads... I would stick with the LS. Cam it, double springs, Ti retainter, ect. Vtec is best for NA. From what i looked into, turbo cams i have looked at for vtecs actually elliminate the 3 lobes stepping, giving 3 lobes of the same size. Duration might differ, but size looks damn near the same. I didnt get to measure with a caliper, but they look DAMN near the same. Im building up my b18 for boost, and im keeping the LS block and LS head.
Old Jun 14, 2006 | 11:13 AM
Iso187's Avatar
Iso187
Watch your stock bottom end too. Stock block boost limit is about 11 psi. I wouldnt go much more than 8, 10 MAX!
