NEED HELP!!! Tranny (LSD) Question???
Old Sep 5, 2002 | 11:49 AM
BoostedAcura's Avatar
BoostedAcura
Default NEED HELP!!! Tranny (LSD) Question???
I really need a good answer to whether or not an LSD from a Type R tranny will fit into a LS Tranny. All are 94+ hydros. I've heard yes and no. I just need a good correct answer. Thanks guys.:naughty:
Old Sep 5, 2002 | 12:13 PM
dubcac's Avatar
dubcac
I
I don't see why it wouldn't fit. Both are b-series trannies and hydro.
Old Sep 5, 2002 | 06:46 PM
kinghawk's Avatar
kinghawk
It will fit
Old Sep 5, 2002 | 11:23 PM
BoostedAcura
Some people say that you need to just change out the end bearing to a type R one. Others say you have to that plus change the final gear to a type r one also.
this is what i say to confusion :madfawk:
Old Sep 6, 2002 | 04:28 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
The diff sizes should be the same, as well as the bearings, you should use whatever final drive came in the tranny to avoid excessive bind or lash though, unless you can verify that the clearances are ok, because you normally have to change the mainshaft to be able to change the final gear size since they're a mated set designed for a certain mesh in the tranny.
-Harry
AIM: NDcissive
Old Sep 9, 2002 | 10:24 PM
Trickturn's Avatar
Trickturn
Balls or just crazy...
Originally posted by 1stGenCRXer
... because you normally have to change the mainshaft to be able to change the final gear size...
Countershaft... not mainshaft :thumbup:
Pete
Old Sep 10, 2002 | 04:24 AM
1stGenCRXer
Pete
Whatever, one of those PITA things
Old Sep 11, 2002 | 09:07 AM
Trickturn's Avatar
Trickturn
Not really a pita. I can have the whole tranny down to just a shaft w/ all the synchros, sliders, & gears in a couple of minutes.
It's all about the 20 ton press in the backyard
Pete
TopSniper69
9
Mar 4, 2007 02:54 PM
anthony12389
13
Aug 23, 2006 05:33 PM
salwan7
Engine Swaps, Tech & Tuning
5
Dec 20, 2005 01:10 PM
93ACCLUDE
Prelude
6
Jan 16, 2005 07:26 AM
tay-fu300zxtt
CRX & Pre 92 Civic
2
Aug 23, 2002 08:47 AM
