So how does this setup sound..
Old May 1, 2005 | 09:22 PM
BoostedITR41's Avatar
BoostedITR41
Originally Posted by pomansouth
about the itr cams, which is cheaper...hmm. Also, I stand corrected, hondata does support 1000cc injectors, the reason that the person that I know opted for aem is the flexibility that aem has since he has free dyno time. It was only a couple hundred more for the ems so he went for it, just gotta get it tuned in now. I never said that ITR cams will not make over 600 whp on boost, I just mentioned that gs-r's will too, and they are a cheaper alternative.
put it this way 84mm B16A motor the ITR cams picked up 54whp over the GSR's. of course that is also a 600whp car which on lower hp the gains won't be as much but still you will see gains
Old May 3, 2005 | 01:08 PM
PHiZ's Avatar
PHiZ
BOOST GOD
The SC61 is overhyped, maybe the 84mm will help it spool before 6k.
-PHiZ
Old May 3, 2005 | 01:34 PM
BoostedITR41
-PHiZ
lol you don't read much do you? it will roll into boost by 3800-4000 and be at full boost well before 5300
Old May 3, 2005 | 03:08 PM
PHiZ's Avatar
PHiZ
BOOST GOD
The turbo is over-reccomended, people are throwing it on setups that it has no business being on. It isn't appropriate for a mild turbo setup. Hopefully the increased displacment on this build will allow it to spool in a reasonable time....
Sorry if I let my real world experience with the turbo interfere with what you've read.
-PHiZ
Old May 3, 2005 | 04:45 PM
BoostedITR41
-PHiZ
http://www.evans-tuning.com/viewtopic.php?t=2032
look at the chart and learn...that is on a 81.5mm bore
Old May 3, 2005 | 08:34 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Full boost at 5250... and?
-PHiZ
Old May 3, 2005 | 09:13 PM
BoostedITR41
it is rollin into boost at 4500 on a 81.5mm bore.
Old May 3, 2005 | 09:23 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Hype.
-PHiZ
Old May 3, 2005 | 09:36 PM
BoostedITR41
Hype.
-PHiZ
I forgot 425whp on pump gas and almost stock bore is hype
Old May 8, 2005 | 10:50 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Thanks for all the info guys.
I know the SC61 is bigg, but on a properly setup motor thats looking for numbers..
I am hoping the 2 liters will help the spool abit, that's also why the c/r was somewhat high.
What turbo does everyone suggest , a little smaller then the SC61 with smaller spool times?
Thanks again for the suggestions everyone.
