ls/vtec not that bad
Old May 8, 2005 | 04:39 PM
JayDeeEmDC4's Avatar
JayDeeEmDC4
so i should be safe if i keep it under 7500?
Old May 8, 2005 | 09:28 PM
Snoopy's Avatar
Snoopy
been there done that
yes if the block is stock keep it below it's old rev limit.
and the work to put oil squirters into a b18a/b block is a bitch from what i hear.
Old May 9, 2005 | 09:56 AM
civicandtegra's Avatar
civicandtegra
he said if i get the head (dont know which i would use), oil squirters, and rest of the vtec stuff, and the ecu he would install and put the squirters in for 600. i have no intension of goin to 8k yet. after i rebuild and lower comp for a turbo maybe. i know a guy with a type-r and 40k into the motor (type-r block, si head.. his old motor blew) and he makes around 650hp professional drag car.
Old May 12, 2005 | 02:59 PM
servion's Avatar
servion
I removed the oil squirters in my GSR bottom end and plugged the holes. I rev to 9.5k all the time (with forged internals) with an LS crankchaft. No problems. Squirters are definitely not necessary if you're running forged internals.
I know many people who run ls/vtec setups reliably daily without oil squirters. Its definitely not worth $600.
Old May 12, 2005 | 07:04 PM
bert3734's Avatar
bert3734
I have an LS/VTEC, with my stock B18A Bottom end and a B16A head with ferrea valves and ferrea guides, type R cams, and type R springs.
My car is now turboed. I LOVE IT.
NO PROBLEMS WHAT SO EVER (Knocking on wood!)
Old May 12, 2005 | 07:06 PM
civicandtegra
well if i keep them for another layer of protection for heat, its not gonna hurt performance will it
Old May 13, 2005 | 05:20 AM
pomansouth's Avatar
pomansouth
for 600 bucks, you can get a gs-r bottom end, and have everything already needed to rev to 9k, except for the main studs.
Old May 13, 2005 | 09:24 AM
servion's Avatar
servion
Actually, they do add a little weight to the pistons (its a constant stream of oil, not spurts), so it actually robs you of some performance (very minor though).
Old May 13, 2005 | 11:41 AM
civicandtegra
i want to keep the ls bottom because it has a larger displacement even though its not much and has lower comp to start
Old May 13, 2005 | 11:47 AM
pomansouth's Avatar
pomansouth
ask your self, where does this larger displacement come from?? It comes from the crank/rod setup, not the actual block. For 700 bucks, you can buy the gs-r block and get a ls crank to suite what you want.
