Installing B20b into 2000 civic si
Old Apr 15, 2005 | 05:35 AM
b18c1_hatch's Avatar
b18c1_hatch
What does a B16 tranny top speed is. Arent they like quick gears stock and top out at like 115 or something. cause i want to know
Old Apr 15, 2005 | 06:04 AM
b16ahybrid's Avatar
b16ahybrid
Depends on your tire size and rev limit, I trap at 118mph and have plenty to go.
Old Apr 15, 2005 | 06:11 AM
b16ahybrid's Avatar
b16ahybrid
Originally Posted by crazy4396063
eh.....7psi...is really nothing esp. for the b16 but if you were to put the b20 bottom end...you'll have to up the boost since the b20 has a much lower compression ratio but no doubt 7psi is safe as long as you tuned it right...you def. did somthing wrong
The b16 can handle more power then the b20 block due to it's design. The b16 block can take 300+whp before you really need to start to worry, while the b20 will probably crack a sleeve before that. The b20 + boost is great if it's built.
On a side note how much power were you making? What size of turbo were you using? 7psi means nothing.
It just goes to show that crappy tuning will destroy a motor not the amount of boost you run.
What exactly broke in the motor? Generally you'll crack a ring land or melt a piston before you break a rod, must have been some pretty severe detonation.
Old Sep 2, 2005 | 04:23 AM
Techme06's Avatar
Techme06
Eg b20b turbo
use this site to see what speed you are travaling at what RPM.
http://www.f-body.org/gears/
use this site to see the gear ratios of the transaxle
http://www.knology.net/~jediklc/D.htm
Old Sep 2, 2005 | 04:30 AM
Techme06's Avatar
Techme06
Eg b20b turbo
compression is kinda high for boost on the b16 . 10.2:1 (jdm10.4:1)with 7psi it isn't going to hurt but at high rpm and tq i'll wear the motor down.
Old Sep 2, 2005 | 05:01 AM
psx_pat's Avatar
psx_pat
Anyone one know,how big the difference of performance after stock B16A engine then change the bottom to B20B? Is it really feel the difference,especially low end torque? And B16A with B20B botttom (all stock) what is the highest rpm is safe for everyday driving? thanks.
