race project
Old Dec 3, 2004 | 10:11 PM
  #31
Kai's Avatar
Kai
Rotorphile.
Originally Posted by BoostedITR41
if you stroke it you will have some insane piston speed. the RS ratio would be a mess
That's not really an issue for a race only car.
Old Dec 3, 2004 | 10:35 PM
  #32
sherwood's Avatar
sherwood
I missed Sean
well it was my racecar project but the title should be changed really... the ideas i have had have changed alot and now that i want to go turbo or FI at least i figure i should be able to get away with it being streetable (and possibly even able to pass emissions if i do things right)
Old Dec 3, 2004 | 10:55 PM
  #33
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by DRfrank
lol, i thought you just wanted me to go turbo... stop confusing me man
I assumed you were sticking to the N/A road, so I suggested something to overcome the short stroke. It is really up to you whether you want to go FI or N/A. The gains will be greater at a given cost for a turbo vs natural aspiration.
Old Dec 3, 2004 | 11:19 PM
  #34
sherwood's Avatar
sherwood
I missed Sean
yea, but my buddy has been upgrading his STI lately, so i can get ahold of his stocker turbo and fuel pump with more things to come ( i think an ls will spool that turbo, if not, i'll jsut buy a t3/t4)
ps.. i hope this isnt my last post here.. lol, i'm goin to bed
Old Dec 4, 2004 | 09:18 AM
  #35
BoostedITR41's Avatar
BoostedITR41
the STi turbo is way to small
Old Dec 4, 2004 | 10:26 AM
  #36
sherwood's Avatar
sherwood
I missed Sean
its effcient for 18 pounds or so, i'm, not looking for like 8000 whp or anything here guys
Old Dec 4, 2004 | 10:34 AM
  #37
BoostedITR41
you will not make any more than 250whp on that turbo really....you need at least a T28 or something close to it
Old Dec 4, 2004 | 10:52 AM
  #38
sherwood's Avatar
sherwood
I missed Sean
not if i put in higher comp pistons and tune right.. i think it should be enough
Old Dec 4, 2004 | 12:31 PM
  #39
Kai's Avatar
Kai
Rotorphile.
The IHI VF39 should be just fine for his purposes.
Assuming you can have fabricated a manifold or adapter plate to work.
Old Dec 4, 2004 | 03:16 PM
  #40
sherwood's Avatar
sherwood
I missed Sean
or i could just find myself a t3/t4 and be done with it
how hard is it to FI a c1 engine if i plug in a EMS? i dont want a crappy EMS either, prolly gunna go with AEM... also, if i got an electronic boost controler, could i theoertically change profiles on the fly wiith the AEM EMS no problem? (it should control all the variables, like timing, boost, vtec engagement, fuel, etc.. correct?).. ok so heres where i am so far:
B18c1 in a hatch or CRX
t3/t4 turbo
built engine with engine block guard (i think this is the thing that connects to all of the mains stabilizing the block.. right?):
midrange compression pistons (with oem headgasket) so i can always change out the gasket to gain/loose a little compression. (prolly 9.5's-10's)
Pn'P on the head
mid-range cams (streetable, yet also raceable)
LS tranny
AEM EMS w/ EBC
