EGT probe install tips?
Old May 13, 2004 | 02:08 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally Posted by 1stGenCRXer
You want to have the probe between 3 and 6 inches from the valve for your best readings. A bung would be a good idea on a tubular manifold as well.
Also, nearly all shared plenum hondas have an air bias problem on cylinder 3, NA or forced, so that would be the best cylinder to monitor if you can't monitor them all.
For the record, I've used EGT's racing 2 strokes [which are far more sensitive to improper A/F ratios than even the most high strung turbo engine] for the better part of a decade.
Awesome, thanks Harry. I knew there was a reason I was going to put it on the #3 runner. h:
Why would a bung be more beneficial if the bolt adapter is properly sealed? I can see where it may cause problems, but is it really that bad?
I went with the Greddy electronic EGT.
Old May 13, 2004 | 02:36 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Having a bung in there would just make the whole thing more secure against vibration. Depending on the size and weight of the probe, it may be a non-issue. Personally, I would probably fabricate or buy a bung the size I was looking for just so I had the piece of mind that it would be more than strong enough to hold up to street use, but I admittedly can get overly paranoid about street survivability.
-Harry
AIM: NDcissive
Old May 14, 2004 | 09:58 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I'd feel a bit weird just tapping a hole into a tubular manifold as well. There's just not much material there. Honda sees fit to weld on bungs for O2 sensor(s), I would do the same for an EGT.
Old May 14, 2004 | 10:03 AM
sensei's Avatar
sensei
I agree, a tubular manifold just won't give you the thread-depth you need for a taper thread fitting to seal properly. Definitely tig it on, just make sure you use a stainless fitting if the manifold is stainless, and stainless alloy welding rod.
Old May 14, 2004 | 10:29 AM
westcoaststyle
I just happen to have a SS rod left over from another project I did so I can use that. I just hope the inner diameter is correct for this. How deep should the probe go into the manifold?
Old May 14, 2004 | 10:12 PM
1stGenCRXer
The tip of the probe should be centered in the runner's diameter.
-Harry
AIM: NDcissive
Boosthead
Aug 16, 2004 03:48 AM
DatHatch219
92+ Civic/EL & Del Sol
13
May 2, 2004 06:58 AM
madlow
10
May 5, 2003 07:52 PM
solRNY
Dec 20, 2002 11:41 AM
solRNY
Dec 5, 2002 08:39 PM
