b20Vtec Leaking
Old Apr 20, 2004 | 09:56 AM
92eg6's Avatar
92eg6
99 CG3 Owner
Default b20Vtec Leaking
my b20 is leaking, IT IS NOT THE HEAD GASKET! does anyone know where it may be leaking from
Old Apr 20, 2004 | 09:58 AM
ISP James's Avatar
ISP James
DAMIMRED
oil feed line into the head :dunno: you should probably be more specific... where is it coming from? the back, front, side? how high is it....
Old Apr 20, 2004 | 11:17 AM
92eg6's Avatar
92eg6
99 CG3 Owner
coming from the passenger side, looks like its coming from the head gasket, i bought a special head gasket had it re sealed 3 times, have arp head studs re tourqed them 3 times, had a machine shop check the head and block levels and they said it looks fine
Old Apr 20, 2004 | 04:30 PM
Kai's Avatar
Kai
Rotorphile.
How was the VTEC oil feed passage sealed? Plugged? Welded? It was plugged, right?
Are you sure the valve cover gasket and cam seals are good?
Step one is always to completely clean the area and wait to see where oil starts coming out again.
Old Apr 21, 2004 | 07:27 AM
ISP James's Avatar
ISP James
DAMIMRED
cam plug seal would be the first thing i would check...
Old Jan 19, 2006 | 05:55 PM
mccoy1178's Avatar
mccoy1178
if u got a vtec head, try the vtec solenoid. common problem with my gsr. good luck
Mccoy
Old Jan 19, 2006 | 10:19 PM
Kai's Avatar
Kai
Rotorphile.
McCoy: This thread is almost two years old. Please don't dig up dead threads as the problem was probably fixed long ago.
crxsiperf
CRX & Pre 92 Civic
8
Apr 20, 2004 08:26 PM
keefungliu
Engine Swaps, Tech & Tuning
2
Sep 13, 2003 09:34 AM
int3gra3
Accord
12
Jul 17, 2003 06:42 AM
nctardevil
Mar 20, 2003 12:39 PM
blkdragteg63
15
Dec 23, 2002 06:41 PM
