Assulting your oil pan
Old Mar 27, 2004 | 12:47 PM
shakes's Avatar
shakes
blah!
Default Assulting your oil pan
so the problem is that my header DP touches the oil pan. i have a couple of options here...
1- spend the $50 and have the header modified (cut and weld in a spacer)
2- i can beat the crap out of my oil pan. i figure a couple good swift hits with a hammer and a block of wood will do well. i just need to indent a 2" wide section about 1/4 - 1/2 inch in, right on the corner.
any suggestions on beating the oil pan, or is that just plain bad? ive been hearing both ways.
Old Mar 27, 2004 | 12:57 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
I wouldn't beat the oil pan, then u risk that the ridge u will create will affect the oil movement in the pan.
Old Mar 27, 2004 | 01:17 PM
shakes's Avatar
shakes
blah!
im not too worried about that. just anything like cracking it etc etc...
i need to become a millionare!!!
Old Mar 27, 2004 | 03:28 PM
sensei's Avatar
sensei
Fix the downpipe, even if you were to bash in your oilpan, the pipe would still be too close to the oilpan. You don't want to unnecessarily heat your oil...
Old Mar 28, 2004 | 07:38 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Some people say that changing the volume of you oil pan (via a big unintentional dent) will cause you to throw a vtec oil pressure code. But I think it's more likely that you're running into oil starvation problems, and that's why vtec oil pressure code gets thrown. In short, bad idea.
-PHiZ
Old Mar 28, 2004 | 08:35 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Sounds like a cheap, poorly made header. Get a new one. :goodjob:
Old Mar 28, 2004 | 09:51 PM
sensei's Avatar
sensei
Default bashing
denting the pan would not change the volume, but would possibly push the oil level up, which could cause the level to be high enough to touch the crankshaft, which in turn could foam up the oil and cause cavitation, which could cause the vtec pressure switch to see less oil pressure..but that's a long shot..
SpeCKDriFt96
Accord
Jul 4, 2003 12:58 AM
Prez808
Accord
5
May 20, 2003 05:37 AM
RiceBoysDream
CRX & Pre 92 Civic
2
Mar 23, 2003 06:12 AM
unisold
Accord
6
Nov 11, 2002 05:34 PM
redheat86
Nov 2, 2002 12:49 PM
