B18B build-up
Old Mar 13, 2004 | 07:48 PM
axhammer's Avatar
axhammer
Canadian Icelander
Default B18B build-up
I am planning to rebuilt my b18b in the summer. I desided to go with aftermarket pistons, connecting rods, rings, and bearings. What i need help is with desiding the compression Ratio i should run(turbo is the future), and what company(name the product it self) to use. I was looking at Eagle because i have used them in V8's and found them tuff.
Also, what can break in these engines under high boost.
THANKS FOR ANY REPLIES!
Old Mar 14, 2004 | 04:26 PM
axhammer's Avatar
axhammer
Canadian Icelander
5 views and no replies, come-on.
Old Mar 14, 2004 | 04:31 PM
qtiger's Avatar
qtiger
For turbo, you're looking at anywhere from 8.5:1 to 9.5:1. Personally, I'd stay at 9.0:1 or higher.
Brandwise, J&E, Arias, Wiseco, etc. Only complaint I've heard about J&E is a bit of noise. Others I'm not very familiar with.
Eagle rods are good, but if you're going to be running a lot of boost the Crower I-beams are tougher. Just depends on how much power you want to make.
Old Mar 16, 2004 | 07:45 PM
theoutsider's Avatar
theoutsider
Default build up
Hey, From my recent experience I wouldnt forget the head. I've heard and been told that there is power to be gained. I recently just put on a Fully built head by crower, ported by portflow and soon to be tuned by a local shop. I cant wait to see the final results. Good luck with your build up!
Old Mar 16, 2004 | 09:05 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Everything and anything.
Bottom-end I run an Eagle rods/Wiseco pistons setup and i'm very happy with mine. I'd say stay in the 9:1 Compression ratio range just to make good power even low amounts of boost. As far as the heads goes....I would swap in some mild~moderate N/A cams(LS cams are horrid, anything is an improvement), some stiff springs/retainers, and give it a nice port match job. Call it a day.
Old Mar 17, 2004 | 09:10 AM
axhammer's Avatar
axhammer
Canadian Icelander
Thanks for the input guys. I wanted to turbo, but wanna do it the rite way, by making the motor stronger. Thankknzzz
b18hatch95
Engine Swaps, Tech & Tuning
2
Mar 17, 2003 06:53 AM
jaje
News & Rumors Archives
6
Feb 26, 2003 06:08 PM
jaje
27
Dec 12, 2002 02:36 PM
SpyruS
9
Nov 13, 2002 07:49 PM
93si4ws
Prelude
24
Oct 30, 2002 07:14 PM
