ecu or piggyback???
Old Mar 16, 2004 | 06:26 PM
akuma's Avatar
akuma
Default ecu or piggyback???
Looking to purchace either one of the following ecu/piggyback systems (GReddy e-Manage, Hondata S200 Systems, or Apex-i v-afc) and was wondering which one is more "tunner friendly" or cost effective if plannig to add more tunnig parts. They are all around the same price and I don't want to waste time or espesially money getting the right one for my current app. I/H/E and sk2 IMF.
Old Mar 16, 2004 | 06:44 PM
shivers's Avatar
shivers
Moderator Alumni
The GReddy or VAFC will definitely help with the mods you've got, but if you plan on taking the car further, you might as well look into the Hondata, Power FC, or AEM EMS. These three systems will not only allow you to extract the most power with what you've got, but they are an excellent foundation to build on for future upgrades (cams, boost, n2o, etc.).
2005 s2000
Old Mar 16, 2004 | 06:53 PM
sensei's Avatar
sensei
In my opinion, the other systems listed don't even come close to the Hondata in flexibility. The VAFC is better than nothing, but you cannot adjust fueling without affecting timing with it because it manipulates the map input signal. You must be able to manipulate fuel calibration and ignition timing independently if you want to get a serious tune going.
Old Mar 16, 2004 | 09:12 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Exactly, hope you're not trying to scrimp on a boosted setup with a VAFC as "fuel management". The amount of timing under boost with an AFC hack setup makes me cringe. In the lower boost ranges(1~5lbs) you can be running as much as 40 degree's of timing advance, above that it tapers off to somewhere around 32-ish if you top out the MAP sensor at 11.5-ish PSI.....Which is still way to much timing for a street car on pump gas, or even high octane with pig rich tuning.
Old Mar 16, 2004 | 11:08 PM
akuma's Avatar
akuma
i plan on going the na route so no boost or n2o will be involved but plan on cam gears and shafts in the near future
Old Mar 17, 2004 | 01:09 AM
TheRooster's Avatar
TheRooster
Former Senior Member
coughAEMcoughcough
A little pricier, sure... but for flexibility it cannot be beat.
Old Mar 17, 2004 | 03:55 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Rubbish.
As always, I would consult with what your tuner is most comfortable with, hondata is quite the robust solution but requires several hundred dollars worth of add-ons to be "self-tunable."
-PHiZ
kenton
Accord
7
Mar 2, 2004 11:48 PM
slpycd7
Engine Swaps, Tech & Tuning
Jul 14, 2003 08:10 PM
VTECxSiR
Jun 10, 2003 11:55 PM
Evilkittie
Jan 9, 2003 10:14 AM
FaLeX
Nov 1, 2002 08:13 PM
