clicking???91 accord
Old Dec 9, 2003 | 07:08 PM
slaphappy's Avatar
slaphappy
Default clicking???91 accord
Every time i start to make a turn in my car i hear this clicking sound (doesnt matter what speed), I was told that it is a cv joint maybe. But im not sure any one no what im talking about? and how to fix it
Old Dec 13, 2003 | 11:40 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
Default Re: clicking???91 accord
used to own one with same problem
broken cv joint
hope this helps
Old Dec 19, 2003 | 02:40 PM
IamNemo's Avatar
IamNemo
You know me...
Used to have a Probe that did the same thing. Everytime you get going it clicks...also when it turns...that's the CV joint. I was going to replace mine on the Probe before it got totaled. Get a shop manual and a new CV joint and it shouldn't be too hard to replace.
Old Dec 19, 2003 | 04:40 PM
Kai's Avatar
Kai
Rotorphile.
OK, the part that is bad is the CV joint. It is part of the axle, when you fix it you replace the entire axle. Rebuilt axles cost around $50 plus core.
It's a pretty easy job if nothing else gets stuck or breaks while you are replacing it.
Old Dec 19, 2003 | 08:06 PM
qtiger's Avatar
qtiger
I'll add to the pile by saying CV joint. It could also be wheel bearing but that's a less likely problem. Check the CV boots on both axles... they're the accordianed rubber sleeves on the axles. Most likely one's torn up and leaking some heavy black lubricant.
