need serious help installing deck im my 92 honda accord
Old Aug 14, 2007 | 04:50 PM
teabagzs's Avatar
teabagzs
Default need serious help installing deck im my 92 honda accord
i need help with wiring an after market pioneer deck in my 92 honda accord, I have the wiring harness and i know what each wire is (cause its clearly marked) but the problem is that the wires that are coming from my car arent and i have no idea what wire is for what and which wires go together, they're all color coded and thats what i need help with figuring out. Please it sucks witout tunes while driving.
Old Feb 21, 2008 | 02:56 AM
wickedfx's Avatar
wickedfx
teg-type-R
I'm sure you got it by now, but in case anyone stumbles on this and needs the info.... here you go.
1990-93 Honda Accord Stereo Wiring
Constant 12V+ White/Yellow
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger Yellow/White
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Old Mar 4, 2008 | 09:31 AM
HECTIC_1's Avatar
HECTIC_1
I have an 02 Civic EX and installed an Alpine, it has a subwoofer control, which wires do I connect to use that feature?
Old Mar 4, 2008 | 10:53 AM
Warhawk's Avatar
Warhawk
There should be 2 special pre outs just for a subwoofer. From the pre outs you run wires to your amp. On my JVC headunit there are 2 RCA cables hanging down labeled "subwoofer".
Old Mar 4, 2008 | 12:05 PM
Tedmond's Avatar
Tedmond
not all alpines have SUB outputs. use the perout you have and available, look for REMOTE TURN or AMP TURN ON LEAD and connet that to your amp.
Old Mar 28, 2008 | 12:32 PM
Stykz's Avatar
Stykz
For putting in the deck, did you also purchase the adapter for the plug in your civic? Because with that, you just match up the colors, then plug it into your car.
Old May 18, 2008 | 12:50 AM
demortey's Avatar
demortey
Here's a wicked resource for all that stuff. I've never had a problem with their information, and i've used it quite a bit.
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Honda.html
enjoy.
Old Jun 17, 2025 | 10:04 AM
daryelcorran's Avatar
daryelcorran
Jennica
2
May 30, 2009 03:08 PM
wadd3456
Accord
10
Jun 7, 2006 04:09 PM
racerdave
9
Jan 11, 2005 11:50 AM
lilteg01
2
Apr 14, 2004 12:42 PM
Matt86
4
Dec 26, 2002 06:51 AM
