DIY HID Conversion Installation
Old May 26, 2005 | 10:33 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Default DIY HID Conversion Installation
This is my first real DIY, so bear with me and if you need better pictures or instruction, feel free to PM me at anytime. This conversion was done with the kit I purchased from Xenith Xenons on this site. Great guy and great kit.
I purchased the 9006 6000k kit for my Integra and these are the steps I used to install it.
Tools needed:
10mm socket (optional)
Procedure:
1. Make sure that you have all the necessary components in the conversion box. They include:
2 HID 35W Bulbs
2 Ballasts with ignitor and polarity adjuster integrated
2 Ballast pads (useless)
Zip Ties
Assorted Screws, bolts, and washers (useless)
Stators (useless)
2. Chuck the instruction "pamphlet" right in the circular file and don't ever refer to it. Firstly, it refers to the hood as a bonnet and secondly, it tells you to remove your headlight assembly and start drilling away with a 22mm hole cutter. :nono:
3. Remove your stock (or xenon piece of shit) light bulbs and leave the harnesses hanging. If you notice, the ballast has a black and a red wire with a prongy thingy at the end.
4. They are making this too easy....Notice the black and red wires leading to the factory bulb harness.
5. I wonder what you do next? :thinking: My guess was to put the prongy thingys into the holes on the factory harness matching up the color wires. Make sure you jam them in there tightly, so that the rubber is insulating the prong and the harness.
Continued (internal picture hosting restrictions are a drag)...
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old May 26, 2005 | 10:46 PM
Provocateur
On permanent hiatus
6. Grab one of the 35W HID bulbs and make sure you don't drop it, scratch it, hump it, breathe on it, throw it in an open flame, etc, etc, etc. My point is that if the glass is scratched or has oil on it from your fingers, it may possibly explode when it has 25,000 volts running through it. Not a good thing...
7. Now insert the wires and harnesses on the bulb into the harnesses on the ballast. There is only one way they can go, so if you screw this up, you need to kill yourself. Then insert the bulb into the headlight assembly very carefully like you would with a normal bulb. Then push the foam around the outside of the hole to insulate it from moisture.
8. Now, the hard part: finding a suitable place for the ballast. The holes in the ballast to mount with screws are useless since they are too close to the body of it, so any screw turning involved won't work. This took me about half an hour. I mounted the passenger side snugly between the ABS relay and ABS modulator. It fits snugly, so I didn't have to tie it down at all. Then I zip tied the wires and tucked them between the ABS modulator and chassis.
9. I also zip tied the passenger side wires to one of the ABS modulator pipes to make sure they weren't going anywhere.
10. The drivers side required a bit more intuition considering the complete lack of anywhere suitable to mount the ballast because of a) moving parts b) hot parts or c) no where wide or snug enough to cram it into. I put it against the chassis and secured it with picture hanging wire on both sides. One wire going through the front part of the chassis and one going through the bolt that holds the windshield washer fluid reservoir filler on. (That is where that 10mm socket would come in handy)
Continued again. I feel like a whore but 5 pics is the limit. h:
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old May 26, 2005 | 10:56 PM
Provocateur
On permanent hiatus
You are now done. Fire those suckers up and pray that you weren't an idiot and put the wrong wires in the wrong sockets. :slap: Mine had trouble the first time I fired them up because only the passenger side worked. I turned them on and off a few times and they eventually both fired up with full force. I guess it is just a break in, or something...
On to the review:
Right off the bat, I noticed a huge increase in visibility in both the side and frontal directions. The 6000k kit has a nice blue tint to it that I was trying to acheive with xenon bulbs, but the visibility sucked ass especially at night and during the rain. I like how the HIDs make the road markings a blueish color so they stand out better. Overall, I think it is a well spent $250. Installation was super easy, visibility is much improved, and they look pretty damn spiffy.
Here are some before and after pics:
Before:
After:
:thumbup:
File Type: jpg
File Type: jpg
File Type: jpg
Old May 26, 2005 | 11:16 PM
XENITH's Avatar
XENITH
HAN Approved Vendor
Looks great, you did an awesome job.
Old May 26, 2005 | 11:23 PM
Provocateur
On permanent hiatus
Thanks man, I try.
Oh, and thanks for the killer deal. :thumbup:
Old May 27, 2005 | 05:13 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Nice work dude! :yes:
Keep me updated on these. I wanna know how long they last. h:
Old May 27, 2005 | 06:19 AM
prelood's Avatar
prelood
Verrrrrry nice write-up, looks great!
If you don't mind me asking, how much did that run you? And where did you get it!
Old May 27, 2005 | 07:24 AM
westcoaststyle
He posted that in this thread. Xenith on here. Look in the FS section. h:
Old May 27, 2005 | 08:31 AM
Provocateur
On permanent hiatus
Or in the sponsors forum. $250 shipped.
Old May 27, 2005 | 01:33 PM
XENITH's Avatar
XENITH
HAN Approved Vendor
:thumbup:
