cold dying battery needs advice
Old Jan 24, 2005 | 07:16 PM
knowjack's Avatar
knowjack
Default cold dying battery needs advice
I've had problems starting my 2000 accord (52k miles) over the last week since it's been really cold. It take about 3-5 cranks to get it going, w/ my foot half way on the gas. I know if I can hold out till the spring I'll be good till next winter.
Just wondering if this will damage my starter or alternator, and end up cost me in the long run?
Old Jan 25, 2005 | 02:03 AM
Honda3002's Avatar
Honda3002
How old is the battery? What kind of battery is it ?( Example is it a optima or a regular car battery. ) A regular car battery deteriates after 2 to 3 years. Even if the battery comes with a 8 year warrenty . The manufactory only garrenties the batteries for 2 to 3 years from the time of sales. Also Why are you putting your foot on the gas pedal, you are more enlikley flooding the engine. try these 2 things the next time you start your car for the first time in morning don't put your foot on the gas pedal. turn the on and wait for 10 to 15 seconds. turn the key off and pull it out of the ingntion. then start the car. with OUT your foot on the gas pedal at all. The car should start with no problem . If the car cranks over and sounds weak in doing so then you need to change the battery for a new one from your local auto parts store. Ask for a battery with more COLD CRANKING AMPS . Your car more enlikley has a battery in it for last 5 years or so. plus the cold cranking amps are probably are 550 or so. Ask for at least 700 cca if possible.
I know I just went thru this problem last year in my 95 civic.
Old Jan 25, 2005 | 06:50 PM
knowjack's Avatar
knowjack
-The battery is the original that came with the car, so 5 years old.
-About the foot on gas thing, I read somewhere online that a richer mixture of fuel and air makes it easier to ignite. Unable to find that site, I found others sayin this does NOT apply to fuel injector cars, and may do nothing or may even damage the engine. Crap. Hope I didn't damage the engine too much in a week.
-Anyway, thanks for the advice. The car almost didn't start on me today, so I'm going to replace the battery tomorrow.
Old Feb 12, 2005 | 08:15 PM
LowSky's Avatar
LowSky
holding the gas down wont do anything in a fuel injected car....if it was a carbrueted engine then if you flooded the engine it wouldnt start... all you need is a new battery
Old Feb 13, 2005 | 06:05 AM
teg92's Avatar
teg92
WHAT OK YEAH!
just get a new one then
