Code 20 Electrical Load Detector?
Old May 19, 2004 | 08:17 AM
compfreak2002's Avatar
compfreak2002
Default Code 20 Electrical Load Detector?
20 Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 92-98
defective circuit or unplugged / defective sensor
where is this sensor located what exactly does it do? would it cause the car not to fire and or not crank?
Old May 19, 2004 | 10:12 AM
JimBlake's Avatar
JimBlake
The ELD measures elecrical load in the car, it helps the ECU anticipate what it needs to do to hold the idle speed steady. In my cars it's built into the fusebox in the engine compartment. I think that location is kinda typical for Honda.
It won't keep your engine from starting & running.
Old Jul 1, 2005 | 09:47 AM
Maxx44's Avatar
Maxx44
Former Vendor
Hi Jim,
You seem to have a lot of knowledge on this subject...I hope. I have a 94 GSR...and the charging system is not working properly...it's not charging the battery. I am trying to locate this ELD....can you help me at all?
Old Jul 5, 2005 | 06:39 AM
JimBlake's Avatar
JimBlake
It's built into the fusebox, like I said, but I don't think that's gonna stop it from charging. The ELD measures electrical load, so the ECU can anticipate what it's gonna do to hold a steady idle. In fact, outside of USA they don't even have an ELD & their alternators work OK.
Check the connections to the alternator. On my '95 there's a green wire that the ECU can use to shut off the alternator. If that wire has a short to ground, it can shut off the alternator even when the ECU doesn't want to.
Old Sep 24, 2005 | 12:18 PM
ukaccord92's Avatar
ukaccord92
h22accord92
speaking of the eld .. im from the united kingdom , i did this h22 jdm swap into my ukdm accord 92 and my idle bounces like hell its the only thing that doesnt complete my swap to make it perfect ..while im driving and just ease my feet of the gas pedal and the idle drops all the way to say 200 rpm and shoots up above 12,000 rpm and then n come back to 900 rpm what can i do to slove this my battery charges at 13.8 volts not the usual 14.4v ish
Old Sep 26, 2005 | 04:33 AM
JimBlake's Avatar
JimBlake
I don't know... That doesn't sound like an ELD problem, more like a problem with the IACV.
Old Jan 9, 2007 | 06:50 AM
purpleheaz's Avatar
purpleheaz
hey i have the same problem as Max44. but i have a 98 integra. what should i do
Old Feb 24, 2012 | 01:43 PM
savage92gsr's Avatar
savage92gsr
So I have this eld light as well on my 92 integra gsr usdm B20 non vtec and was wondering if it won't charge my batt and or will it mess something up if I drive it please let me know because I need to start working and I haven't driven the car because of this email me at 2002Transam.rs@gmail.com the reason I gave my email is I'm new to fourms
Old May 10, 2025 | 10:07 AM
daryelcorran's Avatar
daryelcorran
ls_on_boost
Engine Swaps, Tech & Tuning
Apr 9, 2007 05:58 AM
å
2
Aug 31, 2006 08:59 AM
ocliffie
Accord
3
May 9, 2005 05:56 AM
RensoreK
Accord
5
Nov 27, 2004 06:03 PM
89Teg
92+ Civic/EL & Del Sol
10
Oct 13, 2004 07:48 PM
