Need help detaching shift linkage from tranny
Old Apr 17, 2004 | 01:34 PM
compfreak2002's Avatar
compfreak2002
Default Need help detaching shift linkage from tranny
I am going to pull the transmission out of my honda, I have one arm unbolted but the other is a shaft that travels into my transmission, do i have to pull the rubber sheathing away from the transmission to disconnect the shaft will i need special tools is there a link where i can read or see a diagram?
Old Apr 18, 2004 | 03:12 PM
HatcHBacK3R's Avatar
HatcHBacK3R
you need a small punch, and all you need to do it punch out that push pin which is under that spongy thing
Old Apr 29, 2004 | 09:24 PM
XSrcing's Avatar
XSrcing
pull back the boot, and remove the retaining clip. you will see a roll pin holding everything together. i have found that a valve guide installer is a perfect fit for this.
Old Apr 29, 2004 | 09:43 PM
slammed91-hatch's Avatar
slammed91-hatch
i put a 4 mm socket on an extension and used that, worked perfectly. just make sure whatever you use does not fit inside of the pin, cause it will just spread the pin out and make it stuck in there.
JDM_dc2
Jul 12, 2004 01:41 PM
honda_pilot
92+ Civic/EL & Del Sol
16
Mar 5, 2004 12:18 PM
VtecPwr
4
Feb 10, 2004 04:33 PM
AcsRcool
Accord
3
Jul 20, 2003 06:30 PM
Slacker
15
Jun 12, 2003 11:33 PM
