INstall help coilovers and shocks.
Old Apr 10, 2004 | 09:37 PM
KuttinEdge's Avatar
KuttinEdge
This may help
Shocks/Springs
Old Apr 10, 2004 | 10:08 PM
lkailburn's Avatar
lkailburn
college kid
Originally Posted by KuttinEdge
This may help
Shocks/Springs
damn man, thank you for posting that!! that is a SWEET write up.. i now feel much more confident about doing this myself.
but seeing as how when i go at my DIY projects.. i always go slow and take my time.. i will probably do this over an entire weekend.. literally. i'll probably clean out every nuck and cranny while i'm in there too.
Old Apr 11, 2004 | 10:06 AM
Kat95GSR's Avatar
Kat95GSR
It's not hard, but one suggestion -- instead of using an allen wrench and open-ended wrech to take off the top, like they say here:
"Compress the spring until there is no pressure on the assembly cap. Use an allen wrench and a 12 mm open ended wrench to remove the top nut on the shock assembly. Remove the cap and slide the spring off the strut. Then uncompress the spring."
... use an impact wrench on the nut. It saves a LOT of time and phyisical energy if the nuts are seemingly frozen.
MFG
92+ Civic/EL & Del Sol
15
Jun 24, 2003 05:19 PM
Clean00GSR
9
May 23, 2003 10:31 AM
AccordCoup94
May 22, 2003 02:40 PM
Clean00GSR
3
Mar 10, 2003 10:13 AM
Spec R
2
Aug 28, 2002 08:31 PM
