install Ground Control coilovers
Old Jun 4, 2003 | 08:48 PM
MFG's Avatar
MFG
Default install Ground Control coilovers
i install some GC into my stock struct and it's making a loud sounds like it's hitting shocks to my car? Can someone help me out? :thumbup:
Old Jun 4, 2003 | 08:58 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
did you cut the bump stops in half.
bumpstops equal those sponge looking yellow things, sitting around the polished shock rod.
Project EVA - The Track Package
Project EVA
Old Jun 4, 2003 | 11:41 PM
agent87's Avatar
agent87
Need zzzzz's
This might seem really silly but did you take off or otherwise cut a large portion of the OEM dustcovers off? A lot of people seem to forget about this.
Also, are you sure you installed the washers, bushings, and nut together correctly?
Let us know how it goes.
Old Jun 5, 2003 | 07:48 AM
Outxider's Avatar
Outxider
X-Motoring
did u reinstall with the washers on the bottom and top of the hat?
Old Jun 5, 2003 | 06:56 PM
MFG's Avatar
MFG
i drop the GC coilovers over my stock shocks then i put back all the right washer in the right place...but it seem that the tip under the hood has been raise...is there something wrong? by the way i bought the GC coilovers from my buddy and it only comes with the springs and the ring and tubing it sit on..i'm i missing some pieces? help me out thanks
Old Jun 5, 2003 | 09:34 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Also how much did you drop it? The control arms could be hitting the inside fender wells.
Autocross Help Page
Old Jun 6, 2003 | 11:55 AM
agent87's Avatar
agent87
Need zzzzz's
Check what the others have mentioned. Here's something I whipped up for you to compare against though to make sure you installed everything correctly...
File Type: gif
Old Jun 6, 2003 | 12:34 PM
Outxider's Avatar
Outxider
X-Motoring
impressive illustration. :thumbup:
Old Jun 6, 2003 | 03:35 PM
agent87's Avatar
agent87
Need zzzzz's
Thanks. I've been trying to use MS Paint to explain things more often lately. Hopefully it helps.
Old Jun 6, 2003 | 07:26 PM
maestro5050's Avatar
maestro5050
Good work with that pic!
