Weird starting problem
Old Jun 26, 2003 | 09:13 PM
Kai's Avatar
Kai
Rotorphile.
Originally posted by CRX_stg3
It usually holds at about 500-600 rpms.
An Si should hold an idle around 700-800RPM. Try adjusting it up to 750RPM and see what happens... the car will bog out and die if the idle is set too low.
Old Jun 26, 2003 | 09:25 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Tell us the symptoms again and maybe I can figure it out, seems like a similar problem to one I have.
Old Jun 27, 2003 | 02:49 PM
crxtazy's Avatar
crxtazy
I would suggest to check the fuel pressure regulator first since it sounds like the fuel pressure isn't adequate. After that, check the electronic air control valve (EACV). I had a similar cold start problem with the RPMs fluctuating. I adjusted just the fuel pressure and changed he EACV and it started right away.
Old Jun 28, 2003 | 06:39 AM
Magik's Avatar
Magik
Injector Relay / Injectors?
Main Relay ?
Fuel Pump ?
ECU ?
....just off the top of my head.
What about air...air has something to do with combustion doesn't it?
Jason
Old Jul 18, 2003 | 06:35 AM
mmruma's Avatar
mmruma
Got it. There was a problem with the first generation main relay. During hot weather, the coil in the relay that enables the fuel pump looses it. It can not pull the contact closed. This is probably due to the insulation on the relay coil itself melting or getting soft and loosing it's insulation properties. The Honda dealership is the only local place I found one, but they are available from parts stores on the web. $65 and $54 respectively. Problem Solved!:thumbup:
Old Jul 18, 2003 | 08:41 AM
Magik's Avatar
Magik
That's because the "MR" generates it's own heat when it operates and when it's like 120 degrees inside your car on a hot day...it works like crap...my relay worked all winter...but as soon as it started to get warm...fritz. Replaced, hasn't glitched since...his problem doesn't sound similar to mine though...mine was on startup...not once the car was running.
Old Jul 21, 2003 | 10:58 AM
Pete's Avatar
Pete
Civilian
OK, I'm back off my 3 week vacation and I got my Hayne's repair manual in the mail and it told me exactly what the problem was. It narrowed it down to 3 things:
(1) Loose or faulty electrical connections at distributor, coils or alternator.
(2) Insufficient fuel reaching the carburetor or fuel injector.
(3) Vacuum leak at the gasket between the intake manifold/plenum and throttle body.
Since I have been home, it hasn't done it so I'm just gonna let the sweat roll off my sack. Thanks fellas.
