need help code 9
Old Jun 23, 2002 | 07:48 AM
Project_Rage's Avatar
Project_Rage
Default need help code 9
i was at the strip an had some bad wheel hope after that my check Eng light came on i wasn't able to ind any probs and then later in the day the car started to stuter at 2225 RPM in any gear. This mornin its stuttering at 3000 RPM and not at 2250 RPM ??? i checked the comeputer and its a CODE 9 now what is that mean
this is for a all stock 89 CRX si
everything in the dash is working fine car idels at about 600 RPM no can't see anything wrong no leaks no smoke ??
Old Jun 23, 2002 | 04:04 PM
jaje's Avatar
jaje
HC Racer H5
a code 9 is the crank angle sensor...#1 cylinder position
does your car run worse now?...it means your timing belt could have jumped some teeth on the cam gear and you may need to redo the timing...set all to top dead center
better info on timing belt changes or realignment http://www.crxsi.com/resources/repai...belt/index.htm
Old Jun 26, 2002 | 07:58 PM
sir_crx's Avatar
sir_crx
My old 90 Si hb pulled a code 9...it wound up being a bad connection inside the distributor. Pull the cap off and look at all the connections cause if I remember correctly the sensor is "in" the distributor. That's the 1st thing I'd check.
Old Jun 28, 2002 | 07:17 AM
Project_Rage
cool that sounds like a good place to start. the car has been ok now and the but sometimes the porb comes back up ??? its always at a different RPM to ??.
lkailburn
Aug 19, 2003 06:21 AM
Whitelude420
Prelude
May 27, 2003 05:20 AM
RB
Apr 13, 2003 03:50 AM
